    Dismiss Notice
Connecting A Vfd (huanyang Hy02d223b) To A Tb6560 3 Axis Driver Blue Boards
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by dooshare, Jun 30, 2016.
  1. dooshare
    dooshare Canada Iron Registered Member
    1
    3
    City:
    sherbrooke
    State:
    Province du Quebec
    -Return to Top-
    Hi Everyone, I am new to this site. I am looking all over the web but cannot get any assistance and sure someone had this issue before. I am building a CNC and running into a problem. The CNC run good but want to connect my Huanyang HY02D223B to the TB6560 3 axis blue controller board. The controller board has 3 connectors.
    how do i connect this to the VFD connector panel. And how to set up with Mach3
    This is the 3 pin outs on the Controller board
    I am sure new builders will run into the same problems.
    Bellow is photos of my CNC Build:
  2. countryguy
    countryguy United States Active User Active Member
    190
    43
    Fenton, MI
    City:
    Fenton
    State:
    Michigan
    -Return to Top-
    welll... from the standpoint of the HY device- Mine has RS485 Comms which I'm told the newer units do not have/offer any longer. I believe you can send commands via that communications path? (someone here will know as I use Centroid). On the device connectors you have the option of the following analog controls (from the older manuals anyway): External Voltage 0-5V,0-10V,4-20mA,0-20mA. This means, for example, my Centroid controller sets the speed via a 0-10V DAC. Thus I setup the VFD to this mode of analog control. For Mach 3: I saw this post: https://www.machsupport.com/forum/index.php?topic=14182.0
    Others here probably have some info specific to Mach3. I am looking forward to seeing this done! Hope you'll keep posting your progress.
    tx CG
  3. countryguy
    190
    43
    Fenton, MI
    City:
    Fenton
    State:
    Michigan
    -Return to Top-
  4. dooshare
    1
    3
    City:
    sherbrooke
    State:
    Province du Quebec
    -Return to Top-
    Yes i will For sure i am not the only one that has this combination. I tried on other forums but with no luck. That is why my lock on is Dooshare as i believe we can learn a lot from each other and also support and taking everyone to a higher level.
  5. petcnc
    petcnc Greece Active User Active Member
    173
    43
    EU/Greece
    City:
    Thessaloniki
    State:
    Outside US / Canada
    -Return to Top-
    I'm sorry I cannot help on that but I would like to draw your attention on severe issues with the TB6560 board you use.
    Have a look here on some simple mods you can make to keep it alive for long time.
    Petros
Share This Page
