Most of us were taught to flood the workpiece with coolant the moment the spindle starts spinning. While flood coolant is crucial for washing chips away and managing heat on aluminum or stainless, running full coolant on certain carbide operations can actually destroy your inserts prematurely.
The culprit is thermal shock—the rapid cycle of heating up while in the cut and suddenly cooling down as the insert rotates out or coolant splashes back on it.
Here is a quick look at when to flood, when to run dry, and when to just use an air blast:
1. When to run full flood coolant
What is your general rule of thumb for steel roughing on your lathe—do you drown everything in flood, run dry with an air blast, or adjust based strictly on the alloy?
(If you are looking to restock on heat-resistant CVD/PVD coated inserts or rigid tool holders for heavy turning, feel free to check out our lineup at www.cnchome-beyond.com.)
- Materials: Stainless steel (304/316), high-temp alloys (Inconel, Titanium), aluminum, and soft copper.
- Why: These materials generate intense friction, heat, or sticky chips. Coolant prevents Built-Up Edge (BUE), lubricates the cut, and clears chips so you aren't recutting them in deep bores or grooves.
- Materials: Cast iron, hardened steel (40 HRC+), and heavy interrupted cuts on carbon steel.
- Why:
- Cast iron creates abrasive dust rather than continuous chips; mixing coolant with cast iron dust turns it into a muddy paste that gums up your lathe ways and slides.
- On hardened steel or heavy interrupted cuts, the insert edge reaches extreme temperatures inside the cut. If coolant hits that hot carbide, thermal shock creates micro-cracks along the edge, causing rapid chipping or catastrophic edge failure.
