[4]
D1-4 Spindle Wrench
[3]
[10] Like what you see?
Tozguy
H-M Supporter-Premium Member
Feb 15, 2013
1,375
Likes
846
#1
The T wrench for my D1-4 spindle fits rather loose in the socket of the cam. The cam gets all the torque I can deliver by hand. The sockets are starting to get buggered and will only get worse unless a better wrench is used. Have any of you encountered this problem and how have you addressed the issue?
Note: The socket is 10 mm and I have not been able to find a supplier for a new wrench of this size. The idea of making a new wrench by myself is daunting.
British Steel
Active Member
May 12, 2011
698
Likes
533
#2
Get a 1/2" square drive socket extension bar, grind 1.3 mm off each face of the square (carefully) and deburr, either drive it with a ratchet (my preference) or drill though t'other end and fit a tommy bar, simples!
Dave H. (the other one)
Tozguy
Feb 15, 2013
1,375
Likes
846
#3
Thanks Dave, that is certainly a straight forward solution and within my capabilities.
I have since found that 10mm square key stock fits the socket perfectly. Plus, I happen to have a 10mm square female wrench on hand so maybe together these could work too.
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,720
#4
I use a 10mm drain plug socket with an extension & long ratchet. I never liked using those chuck key style T-handles for the camlocks.
Tozguy
Feb 15, 2013
1,375
Likes
846
#5
Love the ratchet idea Dave and Darkzero. I'm heading out to shop for the drain plug socket.
This place is wonderful!
British Steel
Active Member
May 12, 2011
698
Likes
533
#6
My big (10") 4-jaw takes a 1/2" hex, so I've cut pieces off a 1/2" Allen key and silver-soldered them into 1/2" 6-point sockets that I drive with a ratchet and extension bar, for the 3-jaw and the D1-5 cams I just slip the socket off the bar!
[6]
[5] [7]
