DIY CNC Mill -Fixed Gantry
vicrc
I am new here; I was on CNC Zone many, many years ago. Anyway, I've been busy with my main hobby of building and flying RC. However, I love building tools that help me in my hobby. My first true CNC (25 years ago) was actually a CNC hot wire foam cutter to cut foam wing cores for RC airplanes. The next CNC was a conversion of a mini mill from Little Machine Shop. It was great, but the table size was a bit small, so I built a larger CNC machine out of aluminum and parts from a mini mill. I used it a few times but ended up selling it, as I had no room in the garage that was 20 years ago. For the last 15 years, I have been building 3D FDM printers and have obtained a couple of resin printers. For cutting wood parts, I currently have 6040 CNC router, which I am currently using a Mach3 USB board instead of the electronics that it came with. I have tried cutting aluminum with the 6040 CNC, but it needed an upgrade to do it better. I have thought long and hard about it and decided to keep it as is and build a mid-level (nothing too big and heavy) CNC machine in a smaller footprint, but still have a table size to fit 10"x10" parts. My son had some 8020 (1.5"x1.5" and 1.5"x 4.5" extrusions and thought it would be great to use them instead of 2020 extrusion that I use on 3D printers. Here is the initial design of what it would look like, but of course things change as you end up piecing it together. I have no way of cutting very thick aluminum slabs, so I get tooling plates rems that are precut and get the closest size I can find at my local metal shop.
I have around $1500-$1700 on this build; the majority of it is from these items
Aluminum plates cost me around $200
Ballscrews and linear railes $175
Spindle/FVD $380
Steppers/controllers with Power supply $280
Next was mounting y-axis rails and sub-surface plate which is 5/8" x12"x 23" aluminum as it came from my local machine shop. Notice I have mounted the rails to this plate and the pillow blocks to the base. I have no idea why people mount the rails to the base and the blocks move with the plate, I have always thought that keeping the blocks under the milling head would be ideal, and it would be more rigid this way, plus there is no cantilever effect. Please provide with any feedback on this method would be appreciated.
Next was building the Z-axis plate as I need it to place the blocks for the X-axis rails. My goal was to keep the machine around the size of a 19"x24" cart. Hope the cart can handle it. :rolleyes:
I messed up the screw location for the horizontal base plate and had to move the holes inside so that I could keep the X-axis rails farther apart. I guess the extra holes will keep the machine lighter. At this point, it's already 80lbs. I installed the stepper motors as well and had to 3D print the holders, great they 3D printed as I goofed a few times to get them right. I will be milling those out of aluminum when I get this CNC machine to run. I am using a belt drive for the X-axis to keep the overall machine size to a minimum.
Next was to mount the spindle. I ordered another spindle mount for a double mount, but it came rough and abused; I thought I was buying a new. I sent it back and will order another one.
Wire it up and see if she moves. I am using the RNR controller board and Mach3. I am not familiar with any other CNC software besides Mach3, nor I have time to learn anything new. The only CAM software I have used thus far is CamBam, which I might have to move forward with, but it does work for basic stuff.
That was fast; I just started this thread this morning, and it is finished... well, not sorta. I started this project at the beginning of September.
Currently at this stage in my build, now thinking about where to mount my electronics and the container for cooling fluid for the spindle.
Doing some air cutting.
