Dolphin / Mach3 issues
Katana
Hi All, I'm not a big CNC user tending to want to use it to solve particular problems so i'm not particularly skilled but this issue is doing my head in! I've used a drawing CAD program for 30 odd years professionally in Architecture and this is easy to use when I compare it to other CAD offerings - those being so different, they don't function how my brain says they should, so I stick with what I know. The Dolphin CAD/CAM works ok but needs Windows XP - not an issue as I have a laptop for inside work and the mill is hooked up to a PC running WinXP and Mach3.
So, I draw what I want in 2D and save as a DXF. This I import into Dolphin CAD to create drilling cycles and contour patterns which then gets transferred into the CAM portion to create the G-Code. This is a bit clunky but do-able and the CAM has simulation of the machining cycles to see what is likely to happen and debug any issues before transferring to Mach3, I save these G-Code files as .txt to allow easy transfer into Mach3.
Now I open Mach3 on the laptop and load the part g-code and run it to establish run times and any other bugs. Once this is achieved, ie loads correctly and runs all the way through i'll take it out to the CNC via flash memory and this is where things go awry! Loading the g-code into the mill copy of Mach3, it'll get maybe 20 lines in and loading halts due to errors - something along lines of either zero I and J figures can't be 0 or start radius of arc is not same as end radius of arc !
This is puzzling as Mach3 will run and load the code on the laptop but cannot load on the PC - its the same program. I thought it might be the 'absolute / incremental' set-ups but this is set in G-Code so drew a blank and frustration ensues! Anyone have any idea's. One of the programs attached that didn't work on the mill PC!
Done, and in all the permutations, so not that. I think its possibly a Mach set-up thing maybe but unlikely different versions? I'll do fresh installs on both laptop and PC to rule that out. Oddly I was using the Gecko xml set up on the laptop ( as I use a Gecko G540 ) but seemed corrupted on the PC with one axis (Z) responding to both X and Z commands! Its not the Gecko that's faulty as it works correctly if using MachMill xml ! Very odd !
