- Feb 7, 2013
- 2,485
Today I started to remove some rust on some rusty bolts with the age old molasses soak. This seemed waaaay too slow so I added
a little washing soda to the mix and hooked up the negative terminal of my 12 volt DC source to the bolts and the positive to my
sacrificial anode. At this point the mix is foaming away and my ammeter is reading about two to three amperes. This method will
work both chemically with the molasses and electrically with the applied current. The bolts are laying in the bottom of a plastic
coffee can and at least some are connected to each other so will find out in a few hours if this method proves effective.
