Food Grade Rustproofing?
682bear
H-M Supporter - Gold Member
A couple of weeks ago, I bought a nice White Mountain electric ice cream freezer at a yard sale.
I had previously looked at them on ebay... but they are priced way too high for me, so when I found this churn cheap, I grabbed it.
I've cleaned it up good, and am planning to spin up a batch of ice cream tonight.
The paddle assembly in this churn is made of cast iron... I'm wondering what would be good to coat it with before storing it to keep it from rusting...
Would vegetable oil or nonstick cooking spray work as a rust deterrant?
I don't think RemOil or WD40 would be a good idea...
-Bear
USP-rated mineral oil is safe to ingest, colorless and tasteless. Don't use too much, it's a
mild laxative...
If the patina on that paddle is suspicious, a rub-down with stainless steel wool would be
a possible preparation for oil anointing.
-Bear
I would get pharmaceutical Mineral oil. It won't go bad. Vegetable oil or cooking oil will go rancid.
We have had several of those for years and have never done anything to except wash it and let it dry/.
Are you sure that it's cast iron??
Ours are both aluminum of some sort and shiny to boot.
Noe the brackets, hinge lock and tub rings are what's going to cause you grief from rust.
It's definitely cast iron... it's very magnet attracting...
I'll pick up some mineral oil for the paddle. The rings and bracket will likely get wiped down with RemOil... just because I have several cans of it already.
We made a bucket of chocolate ice cream tonight... and sat around in chairs outside my shop and ate it. Wife and I, both daughters, son in law, and my father were all there... it was delicious!
Good times...!
-Bear
Reminds me of years ago when I used to haul bulk milk tanker from the local transfer plant to a dairy in Des Moines every day.
Had an inside with the receiver for top cream and when we had a gallon or 3 we would invite anyone we knew with a freezer to a party.
Had one once with 5 or 6 different flavors!
What a hoot!!
We like to cook with cast iron. We rinse and scrub vigorously with a metal scrubber. Put on stove to evaporate the water, then rub a couple drops of flax oil. In your case, you may have to use a soap. rinse thoroughly, then dry with a hair dryer. In your case, I'd use food grade mineral oil. I'd found that if the cast iron is thoroughly dry and coated with oil, rust in not much of a problem.
That brings back memories. When I was really young my grandparents had a hand crank one and the grandkids took turns. Later they went to an electric. My dad had a electric. Always thought that was the best ice cream.
Forgot all about them, hmmm.
My dad had a hand crank churn that we used fairly often growing up. At some point, he bought an electric, but I only remember him using it once... then he went back to the hand crank. I don't know why he didn't like the electric churn.
-Bear
