- Oct 31, 2014
- 444
Hi all and thanks in advance...
I got a well-used Foredom flex shaft tool at an auction that needs the switch, power cord and one of the brush holders replaced.
I got it apart to the point that I have the motor winding exposed but the switch, cord and brush holder are at the other end of the motor housing and I can't get the motor winding out to access the 'connection' end of the motor. The motor bell housing is apparently 2 pieces, not 3 and I'm reluctant to hit it too hard to see if I can get the stator loose to have access to the wiring.
Has anyone replaced the cord / switch / brush holder in one of these? Is it likely that the stator is just 'stuck' and needs a good thwack or is there a secret setscrew somewhere holding this together?
Thanks!
Stu
Thanks!
Stu
