[4]
Garlock Seals
[10] Like what you see?
Jason Annen
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jun 6, 2015
247
Likes
165
#1
I need to replace some Garlock seals, and they are old, like 3 digit part numbers. I have searched the internet, and I can't find them. Does anyone have a source for seals that can research the older part numbers? I've emailed Garlock, no response.
Jason
dlane
Sep 27, 2014
2,290
Likes
929
#2
Garlock ? Pics ? What is it going in ?
I'm sure there is a new equivalent , unless your going original
Jason Annen
Jun 6, 2015
247
Likes
165
#3
They are oil seals, Garlock is the brand and they are still in business. Some vendors can look up old part numbers and provide the modern part number.
4gsr
HM Shop Superintendent
Staff member
Aug 8, 2011
4,480
Likes
2,782
#5
Your best bet is take the old seals with you to a local bearing house and let them size them up to current production models Garlock or others make today. If your machine is over 40 years old, there is a very good chance that seal is obsolete anyways. But don't worry, newer seal technology today produces far much better seals than was being made 40 years ago. I've found out from previous seal purchases, they probably will be a little thinner than the originals were, too. Not in all cases, but to be expected in some. Ken
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,357
Likes
3,600
#6
if you take the id, the od, and the thickness, you can get most any seal.
if you can provide me with those measurements, & their use-( high speed, low speed, single lip, double lip, etc)
i can provide you with a common seal part number to order, should you need the extra help:)
HardingeHLV
Swarf
Registered Member
Oct 31, 2016
3
Likes
1
#7
Look for an aircraft parts supply place. There are a lot of Garlocks on jet aircraft in particular. Also a bearing supply should have that cross reference info as well.
[6]
[5] [7]
