Oh, this is mundane. Have a pendant light over a stairwell whose bulb went out. The light is under the 3rd step from the top. This kind of light is a two handed affair to change, need both hands to undo the nut at the top and then guide the bulb and socket out of the round glass globe. I just replaced the light downstairs, which was on top of a ladder as well. At least that one was on flat ground. That replacement was a little touchy since the globe was quite large and I was nearly on the top step of the fiberglass ladder.
If my arms were two feet longer, then I'd be able to reach the stairwell light from the floor above, but getting on a ladder there actually put me another foot away...
From what I understand, one could use a step ladder that has telescoping legs. Just make the top legs shorter. I think that could work, if I could position it close enough, and I was tall enough where the ladder peak was. Dunno, feels sketchy, sketchy enough to make me want to draw some sketches to see if the dimensions are close enough to warrant trying. The ladder I have is aluminum and weighs a ton and I'm concerned about maneuvering it in a stairwell. Looks like an easy way to fall. I don't know how to immobilize the bottom ladder feet from slipping.
Is there an easier way to do this? Limiting factor is whether the ladder will lock in the angular position needed. It looks like it might work. 30 years ago, I wouldn't hesitate. Now, I wanted to do some sketches to see if it was close. Risk is, of course, the sketch has decent measurements in it. I'm presuming the high side approach is better? I could jump towards the top of the stairs if things start to shift?
