- Jun 17, 2011
- 2,062
When I found out that the dovetails on Chinese ways aren't always 60o, I needed a larger dovetail cutter to recut the Y-axis ways on my X2 CNC conversion. I had picked up a couple of 3/8 inserts and mounting screws, so I just had to make the body of the cutter.
I turned the shaft to 7/8" so I can use it in the collet holder on the Victoria and in the R8 collets on the ZX-25 mill.
The holder spun nice and true when I reversed it in the collet to face the cut end.
The trickiest part of the build is setting the height and angle to cut the recess for the carbide cutter. The table on the Victoria is big enough to leave the two vises attached and bolt the indexing head on the free end. A little tight to access the working area, but it's nice not to have to re-true a vise weighing over a hundred pounds. The surface gauge I made was the only way to transfer the recess height to the end mill, then set the DRO to zero. you have to add the thickness of the carbide so the cutting surface ends up at the centre line.
Cutting the recess. You have to love the mystery metal that got magnetized at the scrappers.
The finished product. I'll try it out tomorrow.
