[4]
Indicating in an adjustable 6-Jaw (Fuerda)?
[10] Like what you see?
jaychris
H-M Supporter-Premium Member
Feb 2, 2013
78
Likes
5
#1
I ordered a Fuerda adjustable 6-jaw chuck, since it's what I could afford and I've seen some decent things said about them. I assumed (wrongly I guess), that the adjustment screw would be equally opposed and that adjusting in would be a process similar to adjusting a four-jaw. However, the screws are biased towards each other on opposing sides. There are two screws, about 30 degrees apart on one side and 2 screws, about 30 degrees apart, on the the other.
For the life of me, I can't imagine how the adjustment process is supposed to go. Is this similar to other adjustable chucks or is this unique to Fuerda? Any Fuerda people out there that have some tips? I've played around with it for about an hour now and really all I'm doing is %^!$!# it up.
Jeff in Pa
Active Member
Dec 25, 2012
183
Likes
3
#2
If I understand your explanation, two adjusting screws are at 2 & 4 o clock and the other two at 8 & 10 o clock?
GaryK
In Memory
Rest In Peace
Dec 13, 2012
451
Likes
3
#4
I just bought a Gator/Fuerda 6J chuck a couple of week ago and the screws are opposed to each other. Sounds like they let one slip through QC to me.
I would see if I could exchange it, or at least call them and ask how the fine adjustment screws are supposed to be before you tell them about yours.
Gary
Jeff in Pa
Active Member
Dec 25, 2012
183
Likes
3
#5
OK, here's how I would approach centering. Treat it as a four jaw chuck as far as centering.
with my earlier explanation on location of the adjustment screws, using a marker, make lines at 12:00, 3:00, 6:00 and 9:00. ( if you have different colors, one color at 3&9 and another at 6&12--no colors? make wide and thin lines )
If it needs to move towards the 12:00 position, you would loosen the 10:00 and 2:00 screws and tighten ( snug) the 4:00 & 8:00 screws.
If it needs to move towards the 3:00 position, loosen the 2&4 and tighten the 8 &10 screws.
Let me know if I should explain it a different way.
Jeff
jaychris
Feb 2, 2013
78
Likes
5
#6
Thanks, I will do that. Here's a couple of pics, the first showing two of the adjustment screws and then the chuck rotated 90 degrees. I'm not crazy, right?
jaychris
Feb 2, 2013
78
Likes
5
#7
Ok, yeah, I get that. I'm fine with that process if that's how it's supposed to be. I think I will check to make sure my check was a QC slipup before I spend too much time with it. Thanks for the clear explanation though!
Jeff
GaryK
In Memory
Rest In Peace
Dec 13, 2012
451
Likes
3
#8
Here are pics of mine. The part number for mine is 1-903-0600 (6") then I would say they screwed up.
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,724
#9
Regardless if it's an error or not you can still adjust it fine. Both my 5" & 6.25" Bison 6-jaw Set-Tru chucks have 4 scews that were not exactly opposing each other in line. I'm able to adjust TIR to .0002" without an issue & quickly. Doesn't seem likley that it was an error but who knows. Maybe the steel & semi-steel chucks are different for the Fuerdas? Bison does not make these in semi-steel.
jaychris
Feb 2, 2013
78
Likes
5
#10
Yes, you are correct. I took Jeff's advice (which I am embarrassed to admit I didn't think of in the heat of the moment) and I was able to true it up pretty quickly. It's a bit of a pain fiddling with two screws at once, but it's bearable. I'll find out if it's supposed to be like this or not- if it's not, I'd like to have a correct one, if for no other reason that who knows what else was not QC'd correctly on it.
Regardless if it's an error or not you can still adjust it fine. My 5" Bison 6-jaw Set-Tru had 4 scews that were not exactly opposing each other in line. I was able to adjust it without any issues. My 6.25" Bison 6-jaw Set-Tru only has 3 screw screws & again I'm able to adjust TIR to .0002" without an issue & quickly. Doesn't seem likley that it was an error but who knows. Maybe the steel & semi-steel chucks are different for the Fuerdas? Bison does not make these in semi-steel.
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,724
#11
Is yours the steel (PA) or semi-steel (EA) version?
GaryK
In Memory
Rest In Peace
Dec 13, 2012
451
Likes
3
#13
I would say that it's correct then. The PA has 3 pinions and the EA (like mine) has only 1.
Since yours has 3 there's no way to put 4 evenly spaced holes without conflicting with the one of the pinions.
So it looks like it's supposed to be that way.
You'll just have to get used to it.
Gary
jaychris
Feb 2, 2013
78
Likes
5
#14
Awesome, thank you! I can get used to it, but I feel better knowing that it's supposed to be that way.
Gary
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,724
#15
Yup, I agree with Gary, that's the reason for the offset spacing, the multiple pinions.
I was just out using the lathe & I was mistaken (I'll edit my previous post). My 6.25" Bison 6-jaw does have 4 adjustement screws & are offset, it has 3 pinions. It's been a while since I had the 5" Bison & it's been a while since I needed to adjust the 6.25" (I check TIR often). Not sure why I thought the 6.25" had only 3 adjusting screws. The 5" Bison had 3 pinions too.
[6]
[5] [7]
