Is Your Coolant Actually Destroying Your Carbide Inserts?
Ever pull a carbide insert off your toolholder after a production run and notice micro-chipping or small vertical hairline cracks along the cutting edge, even though you weren't taking heavy interrupted cuts?
More often than not, the culprit isn't bad feed rate or poor tool geometry—it is thermal shock caused by inconsistent coolant delivery.
Carbide thrives under extreme heat, but it hates rapid thermal cycling. When cold fluid hits a red-hot carbide edge in intermittent bursts, the carbide expands and contracts rapidly, leading to micro-fractures (thermal fatigue) that prematurely break the insert tip.
If you want to eliminate unexpected edge chipping and get consistent tool life, here is how to handle temperature control on the lathe:
1. Go Flood Coolant or Go Completely Dry
The Rule: Either drown the cutting zone with continuous, high-volume coolant so the tool tip stays at a constant low temperature, or run completely dry and rely on the insert coating (like TiAlN or CVD alumina) to manage heat.
The Pitfall: A weak trickle or mist that bounces off the chip and splashes onto the tool edge every few seconds is the worst enemy of carbide.
2. Watch Out for Interrupted Cuts
When turning hex stock, shafts with keyways, or parts with cross-holes, running flood coolant causes the insert to heat up in the cut and instantly quench in the air/coolant gap.
Running interrupted cuts completely dry with a tough, high-cobalt substrate grade (like CNMG in a tough P25/P35 grade) usually yields much longer tool life than running flood coolant.
3. Direct the Nozzle Right at the Rake Face
If you do run coolant, ensure the stream is aimed directly into the pocket between the chip and the rake face. Splashing coolant on the back of the toolholder does nothing to prevent thermal shock at the edge.
Have you noticed better tool life running certain steel turning jobs completely dry, or do you flood every pass no matter what?
(If you are looking for tough CVD/PVD coated inserts designed to withstand thermal cycling and heavy steel turning, feel free to check our lineup at www.cnchome-beyond.com.)
By running dry, I assume you mean air blast? Otherwise one gets a lot of recutting.
I almost always run flood on the mill, blowing the chips away may be as important as the cooling. Generally run dry on the lathe, chip removal much less of an issue.
@Karl_T Spot on! Air blast is definitely the secret weapon for dry machining—you get 100% of the chip evacuation benefits without introducing any of the thermal cycling shock that fluid coolant causes.
You made a great distinction between milling and turning, too. On a mill, recutting chips in a cavity or slot will destroy a carbide end mill in seconds, so high-pressure flood or constant air blast is non-negotiable. On OD lathe turning, gravity does most of the heavy lifting for chip evacuation, making true dry turning (or air-assisted) much easier to run safely.
Out of curiosity, are you running air blast through a flexible line/MQL set up on your lathe, or just relying on natural chip fall for OD passes?
