    Dismiss Notice
[Source] Looking For Inserts For A Kennametal Tool Holder
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by pmat, Jan 2, 2017.
  1. pmat
    pmat United States Active Member Active Member
    14
    8
    City:
    West Bath
    State:
    Maine
    -Return to Top-
    I'm looking for inserts for this holder. I don't know where to look. I tried eBay but didn't see any that matched the codes on the holder. Thanks, Paul
  2. Jimsehr
    Jimsehr United States Active User Active Member
    74
    28
    City:
    SOULSBYVILLE near sonora
    State:
    California
    -Return to Top-
    Bad pic but I think it says KTDR 12. I googled that number and came up with a pic of tool and I think it takes a TPG 322 insert.
    jimsehr
  3. pmat
    14
    8
    City:
    West Bath
    State:
    Maine
    -Return to Top-
    On the side it says:
    INSERT BTC 12G BTC 12 KTDR 12C
  4. oldboy1950
    oldboy1950 Active Member Active Member
    73
    28
    City:
    rochester
    State:
    Massachusetts
    -Return to Top-
    there are phone numbers on the kennametal home page you can call for customer support.
    hope this helps.
    Dan
  5. G MORSCH
    G MORSCH United States Carbide Guy Active Member
    51
    18
    Ottertail Lake
    City:
    Richville
    State:
    Minnesota
    -Return to Top-
    PMAT:
    That is an antique... I worked for Kennametal for 35 years and Widia for another 4+ and I have never seen a holder stamped with that many numbers and letters. KTDR-12C = K/Kennametal, T/Triangle, D/15 deg. lead, R/Right Hand, 12/Twelve Sixteenths height and width (3/4"), C/5" OAL. It is such an old holder and it is not offset so I believe that 15 degrees is correct for the "D" lead angle. If the head of the tool is offset, the letter "R" would represent 15 degrees. The nomenclature had me a bit stumped so I took a look at a couple of my old triangular insert holders and the insert letters for similar tools are stamped TP-32, which indicates TPG (all surfaces ground), or TPU (molded, but ground top and bottom) and the insert IC and thickness as: 3/8" IC (Inscribed Circle), 2/16" thick (1/8") and no specification for nose radius. When the ANSI system was adopted by the metal-cutting industry, nomenclatures changed somewhat. That is a good holder and triangular inserts are very universal. The inserts
    are common to nearly every carbide manufacturer and are among the lowest cost inserts you can find. Keep an eye out for sales at MSC and ENCO for TPG's and look for brand names like Kennametal, Seco, Sandvik, and others. Uncoated grades are just fine, look for K313, K68, 883, 370, H13A... you can't go wrong with any of them.
    Good Luck with your new tool!
    Best Regards, Gary
    pmat and 4gsr like this.
  6. pmat
    14
    8
    City:
    West Bath
    State:
    Maine
    -Return to Top-
    Gary,
    Thank you for taking the time to give such a detailed explanation. I picked up the holder at a lawn sale in Waldoboro, Maine, paid 5 bucks I think. Most of my tools and machinery are antiques and have come at low cost. Seems like a lot of old time machine shops have closed. Yet the area I live in has lots of machinists, welders and other craftsmen do to the presence of the shipyard (Bath Iron Works) nearby.
    Thanks again,
    Paul
Share This Page
