Looking to move up in lathe size from my 1236T to a 1440TL-V or similar
Here is the very similar 1440TVS and Tom (at ACRA) very generously confirmed that the depth of the crate is 44". If this is accurate and I have no reason to doubt Tom on this, you can clearly see the machine is 6-8" inside of the front edge of the crate. I suspect it is centered front to back on the crate so the machine is probably closer to 32-36" deep. Unfortunately I need more than probably to make access to enter the shop and space for the lathe to live and operate.
I scaled a screenshot of the CAD drawing from the PM manual as best I could in my CAD software. I think the back of the oil pump case is cut off from this drawing but that was the clearest image of a scaled drawing of the machine I could find:
I just got off the phone with tech support at PM and he was able to measure from the back of the backsplash to the front of the headstock and that was 25". I could see the headstock to cross slide handle being another 10 inches. Removing the handles (which they are probably off during shipping anyway) would reduce the width by 3-4". The VFD cabinet appears to stick out past the backsplash about 2". So the machine minus the handles is probably closer 25+10-3+2= 34" than 42". I sure hope so.
The power cabinet/headstock is 31"wide, with the operating handles total width at the headstock is 36", your rendering is like my machine for the back splash, and handles.
Inside of the back splash to handles assembled is 36 1/2"
No back splash is ~27-28" to the handles.
No, I said that it was 25" from the front of the electrical cabinet to the front of the headstock. The backsplash would make it deeper, but you were planning on removing it.
Thank you so much for making that clarification. I need to get a good number on the dimensions one way or another before I can purchase....and/or I need a bigger shop.
You can remove the back splash, but the limiting factor is the pressurized oil system reservoir and deeper VFD cabinet is what sticks out the most in the back of the lathe. At around 3600 lbs these are very difficult to move even over small bumps. With handles I measure 39", drawing is the RML-1440V which is the VFD. version. Picture below is to the end of the compound handle, with it rotated and to the carriage handle it is 975 or 38.4". The handle is 4". Also if the carriage is moved to the tailstock end and with the back splash removed, you can pass that through first and the headstock end should also be a few inches less in width at the time it passes through. around 850 or 34". The 38" overall width is what was quoted in the same manual.
Talked with PM tech support again and he was able to measure the TL-1640V and it appears that it should fit through the doorway. I may have to remove the threading shift lever to do so, as well as remove the backsplash so the machine can be pivoted through the door. Easier said than done but I am confident we can make it happen. He also confirmed that the TL-1440V and the TL-1640V are in fact the same depth and length. Obviously the 1640 is taller but that was never a concern for me. We are currently reconfiguring the HVAC system so the return air and supply plenums are more compact and running a 30A service to the new lathe location.
there is always the fact that the door is just construction work, never let construction work stand in the way of a good lathe, you need a wider door anyway!
