- Jun 26, 2013
- 191
Greetings all,
I have a question about the proper way to setup steel tubing for milling. I was trying to mill some quarter inch slots into a steel tube (1.5" dia x .058 wall) the other day and discovered that it is apparently more difficult that I would expected... The tube is 4130 steel and has an adhesive backed paper layout stencil applied to the outer surface. For my setup I tried first just clamping the tube in my mill vise (so I was applying clamping force across the diameter of the tube). I didn't crank the vise down too tight because I didn't want to deform the tube. The first slot worked basically ok, but on the second slot the tube started rotating in the vise (not enough clamping force I assume), but cranking the vise tighter just deforms the tube (not crushed, but a noticeable amount)... So, I tried slipping a properly sized piece of solid aluminum rod into the tube. This lets me crank the vise tight without deforming the tube, but I still experience slippage. This time it was lateral movement. I clamped some 1-2-3 blocks to the table on either end to stop that, but then it just started rotating in the vise again. On inspection it turns out the that paper label would just tear and allow the tube to slip...
So - what would be the "proper" way to setup for this type of milling operation? 3-jaw on a rotary table flipped to 90*, with a center tail stock? Since the tube is fairly thin I would think I'd need a chunk of the aluminum rod inside on the chuck end to avoid crushing? But also something on the tail end for the center to ride in? Not sure I see how that could be held in place (without pins or something like that)...
Is there some other setup I'm missing? Let me know how I should be doing this!
Thanks!
PS: assume the tube is only about a foot long, and it's a G0704 mill...
Thanks!
