My next build, PM727 CNC
Thanks guys, but now I want to talk about my BALLS.
I’m using the cnc4rx7 drawings to build off of and I’m looking at the bearing supports for the ball screws. He is using 7202B bearings with a spacer in between. I was thinking of forgoing the spacer and us a 3202 double bearing instead. So the bearing stack up would be 7202-3202-7202, am I crazy for thing this?
Go servos and belt drive. Direct drive servo doesn't make much sense. Belt drive lets you move the serve around some too, which is good for packaging and chip management. Using 2:1 or 3:1 belt drive means you can buy slightly smaller/cheaper servos too. Any dual rubber seal AC bearing is good if it fits or can be made to work, but avoid 7001rr if you can. That's why I used on my mill and lathe and they are impossible to find now. I used single nuts on both machines and after a repack I can get them >.001" backlash, takes some messing though. I know cheap double ballnuts aren't much better, they usually need shimming. I don't know what the double row bearing serves in that stack, just radial load? Surely the two AC's are more than enough. I don't use an inner spacer between them, just preload them appropriately.
The 3202 is a double angular contact bearing as well, I know, it’s overkill having 4 angular bearings on one ball screw end.
Again, I don't know what the 3202 gains you. It might make preload of the two AC's difficult, and you aren't putting that much force into them. My servos are 25lbs max on the output shaft, with a coupler like a lovejoy or oldham, you are far less than that. Even a small AC bearing will have a static loads in the hundreds of lbs.. Dynamic load is roughly twice.
Keep in mind a direct drive servo will run a 5tpi screw fast enough for like 400 ipm rapid, which is silly on 8" of Y travel. Also silly with dovetail ways. Direct drive means you struggle to get accels fast enough to even achieve that, so reduction is good. 200ipm is quick on a mil of that 727 size. On my G0704 I set max to 250ipm, if I machine at 100ipm it's puhsing some crazy MRR for a mill of it's size.
