A lot of guys stick exclusively to positive inserts (like CCMT or DCMT) when they start out because they take light cuts easily and don't load up smaller lathes.
While positive inserts are great for low-rigidity setups, sticking only to positive tooling means you're leaving a lot of edge life—and money—on the table when turning solid steel or cast iron.
Here is a quick refresher on when to run positive vs. negative geometries and why it matters:
Positive Inserts (CCMT, DCMT, TCMT)
Geometry: Built with a built-in clearance angle (usually 7 degrees) underneath the cutting edge.
Best for: Small benchtop lathes, light finishing passes, internal boring bars, and soft materials like aluminum or brass.
Trade-off: You only get half the edges per insert (a CCMT only gives you 2 cutting corners). Because the edge is sharper and thinner, it chips more easily under heavy interrupted cuts.
Negative Inserts (CNMG, TNMG, WNMG)
Geometry: The cutting edge is perpendicular (90 degrees) to the top and bottom faces, relying on the tool holder's pocket angle to provide clearance.
Best for: Heavy roughing, interrupted cuts, cast iron, and medium-to-large CNC or rigid manual lathes.
Trade-off: Requires more machine horsepower and rigid setups because of higher cutting resistance.
The Big Advantage: Double the cutting edges! A CNMG insert gives you 4 usable corners, and a WNMG gives you 6. That instantly cuts your consumable costs in half on heavy stock removal.
When should you switch?
If your lathe has enough rigidity and motor power to take at least a 1.5mm to 2mm (0.060"+) depth of cut in steel, switching your main roughing holder to a negative style like CNMG or WNMG will save you a ton on insert costs over time. But if you're turning thin-walled tubing or slender shafts without a tailstock, stick with positive CCMT to prevent chatter.
What is your default setup for general steel roughing—do you stick with 2-corner positive inserts for convenience, or do you run 6-corner WNMGs to keep running costs down?
(If you are looking to expand your setup with rigid negative tool holders or cost-effective carbide inserts, feel free to check out our catalog at www.cnchome-beyond.com.)
