    Dismiss Notice
Newbie Question- Mounting Chuck To Rotary Table
Discussion in 'MACHINE ACCESSORIES (Tables, Vises, Indexers)' started by WoodenFlutes, Nov 2, 2016.
  1. WoodenFlutes
    WoodenFlutes United States Iron Registered Member
    2
    3
    City:
    Asheville
    State:
    North Carolina
    -Return to Top-
    I'm new to rotary tables. I haven't actually seen one in person. What I need is a 6" rotary table to be used in the vertical position, with a 6-jaw chuck. In the 6" size, many of the rotary tables have 4 t-slots. The front mount 6-jaw chucks will have either 3 or 6 mounting holes. Is it possible to mount one of these on a 4 slot table? Or do I need to focus on the few RTs that have 3 or 6 t-slots?
    Jay
    Subwayrocket and intjonmiller like this.
  2. Ed ke6bnl
    Ed ke6bnl Active Member Active Member
    118
    43
    City:
    Agua Dulce
    State:
    California
    -Return to Top-
    can you mount chuck to an aluminum plate, mount plate to the RT and have the aluminum plate threaded for the chuck bolt holes.
  3. tweinke
    tweinke United States Active User H-M Supporter-Premium
    133
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    I would make a back plate for the chuck that fits the table and then bolt the chuck on after the plate is on the table
    dulltool17 likes this.
  4. Subwayrocket
    Subwayrocket United States H-M Supporter - Premium Content H-M Supporter-Premium
    273
    63
    City:
    Scranton/Wilkes-Barre
    State:
    Pennsylvania
    -Return to Top-
    I bought a chuck and adapter plate for my 10" table from these guys . I wasn't expecting much at such a low price ...when I got it, I center indicated my rotary table, stacked their chuck and plate on it and chucked in a round shaft collar .. . To my surprise, the runout was still almost negligible .
    I had to repeat a few times not believing it . I bought it based on a recommendation from this site . Keep in mind, when you put one of these on your table, you're gonna lose ALOT of Z travel and then u cant get tooling into the quill. If you have a DRO , or a way to return to zero, you can crank the table left or right to insert tooling into the spindle, then return to zero.
    I couldn't fit my drill chuck any way i tried , so I ended up having to use collets with drills to drill holes and that gave me back about 3" of Z .
    http://www.ebay.com/itm/6-adapter-3...le-included-/172105838219?hash=item28124eae8b
    brino likes this.
  5. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    1,917
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    It may help us if you tell us what you are going to use it for and why you need a 6" RT. Sometimes there are other ideas and options that might work better for you.
    Edit: Also, why the 6 jaw chuck, and what size? Is it because you already have one?
    Subwayrocket likes this.
  6. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,322
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    This can be a little tricky. As said above it's just a matter of bolting a back plate to the RT, then bolt the chuck to that............But, you need the buy a chuck that has through bolts from the front. If the chuck mounting bolt holes are in the back, there is no way to get to them.
    Having said that, it is possible to attach a back mount chuck to the RT. You make the adapter plate a little larger than the chuck, and drill & tap bolt holes just outside of the chuck. Then you can make some clamps to clamp the chuck to the adapter plate.
    You could also make a two piece adapter that bolts together, just a bit larger than the chuck for bolt clearance. Machine register surfaces on the adapter for alignment.
    Bob Korves and Subwayrocket like this.
  7. WoodenFlutes
    2
    3
    City:
    Asheville
    State:
    North Carolina
    -Return to Top-
    I might already have my answer. Sounds like I would have to machine an adapter plate to fit between, which I was hoping to avoid. So... it seems like the better option would be to look at rotary tables that have 3/6 slots and mount a chuck with front mounting bolts. That leaves me looking at Yuasa and South Bend rotary tables, with a Gator 6-jaw chuck. Any thoughts on these makes?
    I'm machining blackwood and rosewood to make wooden Irish flutes. I'll be using a small RT in the vertical position with a tailstock. A 4-inch table would work, but I've got room on the milling machine for a 6-inch, and Tormach has a 6-inch tailstock that will accept a mt1 bullnose live center. I'll be machining while turning the RT to mill out wooden blocks for keys. From what I've read, seems the RT is the right tool for the job, verses dividing heads, indexers, etc. And the 6-jaw chuck might be obvious at this point, to reduce pressure on the thin wood.
    -Jay
  8. Subwayrocket
    273
    63
    City:
    State:
    Pennsylvania
    -Return to Top-
    Did you see the link I posted above? Those guys sell the whole outfit with the Chuck already mounted on a plate to the rotary table and you're done. It was pretty cheap and the quality was good. Unless you're looking for The Learning Experience, then that's totally understandable
  9. Reeltor
    Reeltor United States Active User Active Member
    182
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    Jay,
    I am not an expert on rotary tables, please correct me if I am wrong. Since you want to use a 6" chuck, I think you will need at least an 8" Rotary Table. Here is a page from Little Machine Shop for a 6" Phase II Rotary Table. Specifications say it can take a 5" chuck
    http://littlemachineshop.com/products/product_view.php?ProductID=1787&category=1034788869
    If a 6" RT is the largest that will comfortably fit on your mill then you may need to look for a 4 or 5 inch chuck.
    You may be able to get a 6" table to fit a 6" chuck if you can find a way to have the chuck use the MT#2 hole in the center of the RT
  10. atunguyd
    atunguyd South Africa Active User Active Member
    85
    28
    City:
    Durban
    -Return to Top-
  11. Reeltor
    182
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    I knew that there must be another way to skin that cat. ;)
  12. talvare
    talvare United States Ted A H-M Supporter-Premium
    253
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Jay,
    I don't know anything about Irish flutes, so this may not be applicable, but, it sounds like these parts could be very fragile/delicate, hence your desire for a six jaw chuck. Just to give you another option, you may consider using a 5C collet chuck rather than the six jaw. The 5C collets will hold delicate parts much better than the chuck. If the parts are larger in diameter than 1.125" (that's the largest standard 5C collet size), you can use a 5C step collet and machine it to the exact size needed for your parts. Also, if 5C collets would work for you, you may be able to use a 5C spin indexer in lieu of the rotary table. This would be a much less expensive option.
    Just some food for thought.
    Ted
  13. WoodenFlutes
    2
    3
    City:
    Asheville
    State:
    North Carolina
    -Return to Top-
    Ted,
    Good thoughts. The flute body might be made up of 3-5 sections, each fitting together with a tenon and socket. There are silver, D-profiled rings that stick up above the wood, to strengthen the sockets. These would not work with 5C collets, unfortunately. I wouldn't normally install the rings before milling the key blocks on a new flute. However, any repair work would necessitate removing the rings if all I had was a 5C setup, and that in itself could damage the flute. Rings are often installed with epoxy. With a chuck, just open it a bit wider and insert until the ring is just inside the jaws before clamping down on the flute body.
    Thanks!
    Jay
  14. dulltool17
    dulltool17 United States Active User Active Member
    81
    28
    City:
    Weaverville
    State:
    North Carolina
    -Return to Top-
    I've built a plate that fits my 4" RT and attaches with 6mm socket heads. My 6" lathe chuck attaches with socket heads from the back of the plate. In this case, the bolt pattern for the chuck was just big enough to cleat the RT.
  15. petertha
    petertha Canada H-M Supporter - Premium Content H-M Supporter-Premium
    136
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
    I just went through a variation of this for more conventional (metalworking) application. here are some other considerations FWIW.
    A plain back chuck that you would probably select for mounting to RT might come in 2 flavors: Front mount (bolts pass from jaw side through chuck body & then into adapter plate). And rear mount (the backside has tapped holes to receive bolts). Some chucks may even offer both. I would encourage you to carefully check the catalog & specs. Some offer front mount, but only within a certain range. For example FM for 6" & larger but then RM for 5" & lower. And from personal experience, sometimes the catalog posts a generic picture for the entire chuck range which can be misleading. So looks for the ** fine print or confirm with vendor.
    Easiest apparent solution would be a FM chuck that bolts directly into the t-slots of RT with no inter-plate. But you need to confirm some things. A typical 3 jaw scroll chuck would have bolt holes further out on the periphery (to avoid the scroll) & would likely be 3 bolts (to be spaced between the jaws). I'm not sure what 6-jaws have. But my point is 3-pattern chuck bolts holes wont engage a 4-slot RT, but would fit a 3 or 6-slot RT. And obviously the bolt hole circle diameters must be accommodated. Personally I wouldn't choose a specific RT model solely based on chucks (unless you have an expensive one you want to utilize). Because there are many other RT specific purchase considerations.
    Centering. If your woodworking application is not fretting about a few thou here then lucky you. For precision metalworking its often necessary to ensure chuck clamping is absolutely concentric with RT rotation axis. I've had pretty good luck with most jobs dropping an morse taper arbor into the RT, lightly closing the chuck jaws down on the extending stub, then clamping the chuck to RT into that position. But you can only do this with either a FM chuck or an inter-plate ie. an assembly that facilitates the chuck being able to float a bit & then clamped down. If OTOH the chuck is 'fixed' to the RT by some rear mount centering plate & no way to adjust it, that can introduce runout & you are stuck with this. So another option is get an independent jaw 4-jaw chuck which you can dial in to the work, same deal as a lathe setup. This also allows you to hold non-round work & offers 1 more jaw over a 3. But that takes more time to set up each job.
    Other RT purchasing considerations. If you are holding things that require tailstock support in vertical mode, consider looking for brands that sell matched tailstocks. If you find yourself wanting to index to fixed divisions repetitively (as opposed to rotating or arriving at odd angular increments) then consider getting dividing plate set that might be offered with RT. Also, you may want to look at a dividing head which is a different animal but may offer some advantages over a RT.
  16. petertha
    136
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
    Here is a sketch of a Gator 5" dia 4-jaw independent chuck perched on a 6" dia RT with 4 T-slots using a self-made inter-plate just to give you a visual. I just received the chuck so will be starting on the plate soon. The 4-jaw chuck has 4 rear mount (only) threaded holes for mounting. I checked the 5" gator 3 jaw & it has 3 holes but same circle pattern & same recess in the back (red arrow). So that's why the odd looking bolt pattern in the plate - so I can both 3 & 4-jaw chucks on same plate.
    Re chuck recess - pretty much every plain back has this & its intended to engage a matching protruding boss typically on the lathe adapter plate. But the diameter & depth vary my manufacturer. And don't get this confused by Set-Tru & similar 'adjustable' chucks, those are different again. Anyway, thinking about this some more, I think I want a similar protrusion on my adapter plate as opposed to just flat. If the chuck is only clamped with the bolts, it probably wont move around in horizontal mode. But in vertical mode the chuck's weight wants to slide it down. Now add any quill machining force on top & that might nudge things if the bolt hole clearances will allow it. But then again - its only 4 bolts that are holding the plate to the RT. :) I'll let you know how/if it turns out :)
Share This Page
