Old Westinghouse Motor Turns The Wrong Way!
Glenn Brooks
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Nov 14, 2014
650
Likes
664
#1
IMG_1206.JPG IMG_1205.JPG IMG_1204.JPG hello all,
Well, finally got finished restoring my old 1919 Dalton 7 x36 lathe tonight. Threw the switch to take a test cut and low and behold noticed the chuck was turning the wrong way! The antique Westinghouse 1/4 hp motor I sourced some time ago, and recently installed, apparently is wired to turn CLOCKWISE -which spins the lathe in reverse!
Anyway to rewire this thing to turn counterclockwise. I only see two terminals for the (110v) load. Here are some pics of the business end of the motor.
Thanks much,
Glenn
Heckle and Jeckle
Active Member
Active Member
Oct 5, 2016
78
Likes
41
#2
Two choices, run the belt with a figrue 8 in it or physically 180 the motor and remount in the housing if there is room ... Not changing the direction moving the wiring..
tq60
Active Member
Active Member
Jan 11, 2014
510
Likes
254
#3
Label does not state rotation and second photo looks like starter.
Look close for a third wire that is connected to one of the line wires.
You also can try contacting manufacturer or visit an old school motor shop and ask.
It is likely a 5 minute task.
CluelessNewB
Active Resistor
Mar 3, 2013
980
Likes
422
#4
It's hard to tell from the pictures but I suspect you can change the direction. I don't see any capacitor but I do see a starting switch so I believe it is a split phase motor. You may need to un-solder and re-solder some wires. (Edit: no it looks like just some screws!) You need to swap the electrical relationship between the run and start windings. Attached is a diagram. The start winding is the one that has the starting switch attached.
ddickey
Apr 21, 2016
1,005
Likes
505
#5
If you can get to the starter winding you can reverse it. How many leads coming out of the motor?
Uglydog
Dec 6, 2012
2,220
Likes
1,209
#6
markba633csi
Active Member
Active Member
Apr 30, 2015
1,311
Likes
518
#7
Glenn I marked up one of your pix- the red arrow is one end of the start winding, the other end is among the ones above (yellow arrow).
Isolate the start winding and swap the ends, should reverse it.
PS you know it's an old motor when it says 110 rather than 115 or 120!
Glenn Brooks
Nov 14, 2014
650
Likes
664
#8
Thanks, Mark. The arrows in the photo are very, very helpful. The top three wires, one of which is adjacent to your yellow tick mark are buried inside the motor. I'll try to open it up a bit more tomorrow. I reckon the motor might be an early 1920's model, judging from the wiring harness and architecture of the case.
Glenn
markba633csi
Active Member
Active Member
Apr 30, 2015
1,311
Likes
518
#9
Put some little masking tape labels on the wires when you start undoing them Glenn, it really helps I've found.
Mark S.
Oh BTW I don't think you need to go deeper into the winding side of the motor; the wires you need are right there in the photo of the end-bell wiring. A closer-up view of how those three upper (yellow arrow) wires connect to the outside world would be helpful. The other end of the start winding is one of those 3, I'm pretty sure.
Container Above bottom breadcrumb
