- Sep 11, 2012
- 329
As a retired electrician wannabe machinist all I can politely say is all those phase converters and static units are obsolete pieces of s--t. VFD is the only way to go as they offer overload protection, and direction control as mentioned but so much more. 1 phase to 3 phase conversion to 5 hp is the largest I ever installed for 240v rated motors. Also infinate speed control from 0 to name plate rating. Under voltage/over voltage protection, phase failure protection, your motor never had it so nice. Preset speeds can be set up via switches for different operations. Ramp up to speed time curve for gentle start ups and ramp down time curves for a nice easy stop.
Now the down side, these VFD's use very high voltages and frequencies to do their job. Old, older motors have insulation for the windings that is not rated for this use. Most motors will stand up in my experience, but early failure is also possible but slight. Operating the drive in constantly below 25-30 Hz is not generally recommended as the cooling fan on the motor is less efficient and the motor will overheat from thermal problems, not electrical problems. If you must operate at that speed, gear it down.
All things weighed out, the Variable Frequency Drive is the way to go. These come in two basic styles, constant torque, and constant horse power, tell the salesman you want one for conveyor duty (constant torque), or fan duty (constant horsepower). Lathes, mills, drills, etc utilize the constant torque version as the load is variable. Fan duty the load is constant. You have reached the limit of my talents but I believe by experience I am correct. :thumbzup:
