PM 8" AC-8-3 3-jaw chuck - Where can I find hardened jaws that will go to almost 0" diameter holding?
SquareJ
Looking for some hardened jaws that will hold smaller than the 5/16" minimum of the standard jaws. I'd prefer hardened not the soft ones on their site.
Aw man, id be swapping collets all day. I don't need the precision they provide just the capacity for small parts. Is there a name for the particular mount type of the existing jaws that I can use for a search?
An old Jacobs headstock chuck might work, if you have a threaded spindle.
Sent from my SM-S911U using Tapatalk
Not sure if that chuck has the American standard grooves or metric, you should be able to measure the grooves and figure out which it is. I’ve only seen pointed jaws in aluminum, but you might find something here that works.
Wow, the quote for 3 jaws was $850 from
Dillon. Will see what PM quotes for another set and grind them do do what I need. Thanks for the link so I had someone to compare to.
Really the wrong approach for small diameter work and makes the chuck have less grip for anything larger. You will find that trying to hold small diameter parts in a 3-jaw they will just push out between the jaws and offer poor holding power. You would be much better off holding a collet arbor in the 3J and then using small collet set to hold small parts. You can use a collet block or a straight shank arbor in your 3J, something like an ER16 set below. I have a Kennametal small arbor with a straight shank that takes DA collets and can go down to very small diameter stock, but primarily use my 5C that goes down to 1/16". ER collets are a bit more versatile in that collets usually have a wider clamping range then 5C or DA. I would not do small diameter work with an 8" 3J chuck, I do have an 8" 4J combination chuck that will hold stock down to 0.2" but would not use it as such.
ER16 Collet Chuck
ER-16 Collet Set 12Pcs ER-16 Spring Collet Set 1/32-3/8 Fit for CNC Milling Lathe Tool
Small diameter work with a 5C collet chuck
