PM-833T DRO REFINEMENTS
RIMSPOKE
Jan 16, 2016
302
I FINALLY FINISHED UP MY DRO INSTALLATION NOW THAT I HAVE A CHIP TRAY UNDER PM-833T MILL .
WHAT's NEW IS A LOWER COVER FOR THE Y SCALE AND A 1/4" ALUMINUM END CAP .
THE UPPER COVER HANGS OUT FARTHER THAN THE LOWER ONE SO ANY CHIPS THAT GET DOWN THERE WILL FALL ON THE OUTSIDE .
THERE IS A DRAG CHAIN INSIDE THAT HOUSES BOTH THE X & Y CABLES .
IT ANCHORS IN THE BACK AND TRACKS PERFECTLY THROUGH THE RANGE .
THE Z AXIS CABLE ALSO RUNS THROUGH A DRAG CHAIN THAT HOUSES THE POWER TO THE MOTOR AND THE LED WORK LIGHT
THAT MOUNTS AROUND THE SPINDLE . CHIPS NEVER GO THERE BUT I MAY TRY TO MAKE A COVER FOR THAT ONE TOO .
What size drag chain did you purchase and where did you get it from?
Thanks
THE X-Y CHAIN IS 10mm x 20mm ( INSIDE DIMENSIONS )
THE Z/ POWER CHAIN IS 10mm x 30mm . ( WIDER BECAUSE IT ALSO CARRIES THE LEAD FOR THE Z AXIS LIMIT SWITCH )
I BOUGHT THEM ON E-BAY , 10 x 20 CHAINS ARE SURPRISINGLY CHEAP !
https://www.ebay.com/itm/10-x-20mm-...epid=0&hash=item33d4d10993:g:HCsAAOSw-0xYTNSb
https://www.ebay.com/itm/10x15-10x3...hash=item1c89cddd18:m:mXl4aGjc5bKbfcgezc--cfA
Thanks for the response, and appreciate the links.
With the open type does it get chips in between the links or is it mounted far enough away to not be a problem?
Or if it does how do you deal with that?
David.
THE Z/POWER CHAIN IS UP ON THE SIDE OF THE MILL WHERE CHIPS DON'T NORMALLY GO .
IT IS OPEN BUT I HAVE YET TO SEE ANYTHING GET IN THERE .
THE X/Y CHAIN IS MOSTLY ENCLOSED WITH THE UPPER COVER HANGING OUT FARTHER THAN THE LOWER ONE .
I RUN PAST IT WITH A VACUUM ONCE A DAY .
THE ONE SHOT OILER MAKES PUDDLES ON THE OTHER SIDE SO I AM QUITE GLAD I DIDN'T
PUT IT ON THE SAME SIDE AS THE Z CHAIN !
Rimspoke, thanks for the quick reply and as I didn't say so before very nice work on the installation of your DRO.
Cheers,
David.
