Pm 932 Quill Stop Mods
rherrell
Mar 25, 2015
95
I wanted a quill stop that would be SOLID and adjustable to .001"
I bought an AMERICAN made micrometer quick stop and it works really well. I used 1/2"x 20 threaded rod and made the jam nuts from 7/8" hex stock.
I used 3/8" bolts and bolted everything through the existing holes in the head casting. I s$#t canned the original quill DRO and installed a Mitutoyo.
This shows the quick stop that I can put underneath and stop the quill from retracting. This is especially useful when you have the head locked for your longest tool and you want to drill a bunch of holes with a short drill bit, you just snap the stop in place so you don't have to retract the quill all the way .
I used 1/2" and 3/4" crs because that's what I had and I'm glad I did because it's SOLID!
Thanks for looking!!!
"AMERICAN made micrometer quick stop"
Where does one find such a device? I've had need for such things in numerous sizes and always ended up improvising with simple double nuts the take a long time to adjust.
This is a great idea, thanks
CHuck the grumpy old guy
Thanks Chief, I probably looked right at them in the past but without know what they really were.
How do these work internally? Obviously the button somehow pushes a section of internally threaded material away from the threaded rod.
But, spring loaded and from the opposite side of the threaded rod?
Hmmm. Going to have to think about this one.
I got mine here... http://www.mscdirect.com/product/details/09506114 but the one from Grizzly is cheaper and it says it's Made in U.S.A.
You're correct about how it operates, only half of it is threaded. You depress the button for the "quick" movement and then you can rotate the whole thing for the "micrometer" movements. I've been playing around with it and it seems to hold it's position really well. I set it and then let the quill snap back from about 2" and it stays set within .001" so I'm pretty happy with it.
Thanks again chief. Now I'm going to have to figure out how to make one of these things.
It is on the list for my G0755 also, I will post my progress when I get started. I think that I am going to combine the quill stop mod with the Igaging Absolute DRO install so they can share the same bracket on the quill.
View attachment 115107 View attachment 115108 View attachment 115109 View attachment 115110 View attachment 115111 View attachment 115112
Great mod, one that I would like to do. One question: What is the best way to fasten the display box so it won`t move while raising and lowering the quill? Do you just make a mounting plate using the 4 screw holes in back, or? Thanks, Art
