    Dismiss Notice
Pressing A Bench Grinder Spindle Back To Spec
Discussion in 'MACHINE RESTORATION & WAY SCRAPING' started by Ozwelder, May 3, 2015.
  1. Ozwelder
    Ozwelder Australia Active User Active Member
    30
    28
    Mackay, Queensland, Australia
    City:
    Mackay
    State:
    Outside US / Canada
    -Return to Top-
    I have a 8" 1 HP bench grinder that had something fall on it when in storage.As a result the spindle suffered a bend about where it exits the case. Dial indicator says .012" run out.
    It was a Taiwanese bench grinder but good quality for its day as it is about 30 years old and before its accident was good performer and would run on for a couple of minutes after switch off.
    I can disassemble to the stage where I can put the spindle with attached rotor under a hydraulic press in vee blocks.
    Is the best way to straighten the shaft or is another way recommended?
    Thank you
    Ozwelder
  2. kd4gij
    kd4gij United States Active User Active Member
    996
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    You got it. That is the way I would do it.
  3. The Liberal Arts Garage
    The Liberal Arts Garage United States Active User H-M Supporter-Premium
    104
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    .012 inch is about the maximum I would straighten as above. Even here, I would
    check the point of bend with a drop of dye and a good magnifying glass....BLJHB
    brino likes this.
  4. barnett
    barnett H-M Supporter - Premium Content H-M Supporter-Premium
    52
    28
    City:
    Vienna
    State:
    West Virginia
    -Return to Top-
  5. The Liberal Arts Garage
    104
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    If a stress crack is starting ( very dangerous! ) the dye will seep into
    the crack and make it more visible.......BLJHB
  6. Ozwelder
    30
    28
    City:
    Mackay
    State:
    Outside US / Canada
    -Return to Top-
    Ah hah! potential cracking ! Something I should have thought about! I am fortunate to have once worked in NDT and have access to some die check and developer.
    Many thanks for the replies.
  7. BigWeld
    BigWeld United Kingdom Iron Registered Member
    1
    3
    City:
    Newport
    State:
    Outside US / Canada
    -Return to Top-
    Is it possible to machine out the 0.012" and fit the stone/wheel on that side with a slightly bigger spacer?
  8. FOMOGO
    FOMOGO United States Active User H-M Supporter-Premium
    1,127
    113
    Colorado
    City:
    Steamboat Springs
    State:
    Colorado
    -Return to Top-
    The press should work fine. The 5 hp 3ph motor that came with the rpc I have for my mill had a bent shaft. I was able to get it almost perfect with out much effort. Mike
  9. The Liberal Arts Garage
    104
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    Trim to "straight"shrink on a thin sleeve ( wheel andwashers length,true up threads)
    Get experienced help on site....... BLJHB
  10. Tony Wells
    Tony Wells United States Vice President Staff Member Administrator
    19,349
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    I wouldn't even tear it down. Mount it securely, find a long enough piece of close fitting tubing and bend it by hand. It's already in the bearings it will run in, so better than vee blocks. Should be able to get it plenty close.
    intjonmiller, brino and JimDawson like this.
  11. Lamar
    Lamar United States Swarf Registered Member
    1
    3
    City:
    Benton
    State:
    Tennessee
    -Return to Top-
    There is a place in Cleveland, Tn called Flame Hardening that specializes in straightening shafts of all kinds did some work for me very reasonable
  12. Ozwelder
    30
    28
    City:
    Mackay
    State:
    Outside US / Canada
    -Return to Top-
    Thanks Lamar,
    I am in Australia the shipping might be a trifle expensive.
    I believe I shall have a go at this method.
    Thanks for your replies gents,
    Grahame
    intjonmiller likes this.
  13. intjonmiller
    intjonmiller United States Active Member Active Member
    676
    93
    City:
    Layton
    State:
    Utah
    -Return to Top-
    I just discovered this same issue with my own. I had two, gave the nicer one (older Buffalo) to my brother because he didn't have one for his shop. Now I finally get around to mounting a grinding wheel on the remaining one (a Harbor Freight special I had only ever used for buffing, and hadn't used at all in a solid decade) and discover that the shaft is bent on the left side. Minimal vibration when I mount a wheel on the right, but terrible if I put one on the left. I haven't measured how bad it is yet, just trying to figure out how to approach the problem. Thanks to everyone for already having information for me to find. :)
  14. The Liberal Arts Garage
    104
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    I discussed this problem (with others adding more good thoughts) some time ago
    See if you can call back that thread......BLJHB
Share This Page
