    Dismiss Notice
Rotary Table Brain Fart
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by jmcghee, Jan 2, 2017.
  1. jmcghee
    jmcghee United States Steel Registered Member
    0
    8
    City:
    Peoria
    State:
    Illinois
    -Return to Top-
    Hey guys-
    I suspect I'm missing something pretty simple, but can't for the life of me sort it out. Here's the situation: the 1.5" measurement is machined, but none of the 2.2" diameter is. I need to poke a hole in the center of the 2.2" that I can use to center the part on the rotary table under the spindle. The hope is to very carefully blend the 2.2" diameter with the small radius left by the 1/2" endmill with a nice finish on both sides. Using the right triangle formula (adding .250 per side to account for the 1/2" tool) I'm coming up with 1.814 (rounded) of which I need to take 1/2 to get to the center... so .907. So far so good right? The problem is when I actually do the machining, it becomes apparent that the .907 number is visibly too small... by probably 50 thou or so. If I hit the 2.2" measurement perfectly, there's still quite a ways to go before the curves are blended. If I keep going until they're blended nicely, my diameter goes down to about 2.1". Like I said, I know I'm missing something obvious, but figured I'd ask for help before I waste any more time/ material. Thanks in advance!
  2. mmcmdl
    mmcmdl H-M Supporter - Premium Content H-M Supporter-Premium
    213
    43
    Maryland
    City:
    Fallston
    State:
    Maryland
    -Return to Top-
    Trig it out . Your Y is 1.0 and your hypotenuse is 1.35 .
  3. jmcghee
    0
    8
    City:
    Peoria
    State:
    Illinois
    -Return to Top-
    That's what I did... still coming up with .907
  4. Badspellar
    Badspellar H-M Supporter - Premium Content H-M Supporter-Premium
    37
    13
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
  5. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    525
    113
    Central Minnesota
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    I come up with .907 also. I even laid it out in CAD to see what it came up with. Same thing, 0.907"
    Let me know and if you want I will post the drawing.
    ON EDIT: Badspellar beat me to it.
  6. jmcghee
    0
    8
    City:
    Peoria
    State:
    Illinois
    -Return to Top-
    So it turns out this post was appropriately named... I set the zero wrong, so it was off by the amount of backlash in my mill :\
    Sorry for the interruption, carry on ;)
Share This Page
