    Dismiss Notice
Someone Let The Smoke Escape From The VFD
Discussion in 'SAFETY ISSUES & EQUIPMENT' started by Mark in Indiana, Oct 25, 2014.
  1. Mark in Indiana
    Mark in Indiana United States Active User Active Member
    206
    43
    City:
    Evansville
    State:
    Indiana
    -Return to Top-
    Hello Friends,
    At the shop that I currently work at, I was called to check out a drill press that malfunctioned. The operator said smoke came out of the control box, which enclosed a variable frequency drive (VFD), to control the drill speed. So after opening the box, I found the cause of problem (see picture).
    I can fix electric but I can't fix stupid and lazy. Does anyone else have examples of stupid and lazy?
  2. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    606
    113
    On the shores of Lake Woe-is-me
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    Yup, once the magic smoke gets out they don't work again!
    Using a piece of wire in place of a fuse is just a recipe for disaster. The whole thing is more than likely toast by now.
  3. Mark in Indiana
    206
    43
    City:
    Evansville
    State:
    Indiana
    -Return to Top-
    To a hobbiest, not protecting a VFD is a mistake that costs a few hundred bucks for being too lazy to use a 25 cent fuse.
    Years ago, I worked at a plastics processor that had a machine that someone put 1/2" pipe nipples in the main fuse holders of a thermoforming machine. The building burned down as a result.
  4. pdentrem
    pdentrem Active User Active Member
    177
    63
    City:
    Niagara Region South
    State:
    Ontario
    -Return to Top-
    Just another version of the "Never Blow Fuse". Electrician was showing us some steel pieces someone had put in a fuse/disconnect box at another business. The machine was only protected by the main fuses for the building - 400 Amp fuses! They were only discovered due to a oil fire and the damage they came in to repair.
    Pierre
  5. 12bolts
    12bolts Global Moderator Staff Member Active Member
    317
    83
    City:
    Hinchinbrook
    -Return to Top-
    Always use the appropriate rated fuse in your equipment
    Cheers Phil
  6. David S
    David S Canada Active User H-M Supporter-Premium
    523
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    Ha Ha Phil.
    Love it.
    David
  7. Shopdawg
    Shopdawg Iron Registered Member
    0
    1
    City:
    Oklahoma City
    State:
    Oklahoma
    -Return to Top-
    Shopdawg's Rules of Industrial Maintenance #26
    • [SIZE=+1]Smoke is an excellent indication that the electrical problem isn't fixed.[/SIZE]
    http://shopdawg.com/rim.html
  8. Shopdawg
    0
    1
    City:
    Oklahoma City
    State:
    Oklahoma
    -Return to Top-
    You can also use a mini-breaker. It isn't much more expensive than a fuse holder. We use them on all inputs and outputs on our PLC's
  9. jumps4
    jumps4 Global Moderator Staff Member Active Member
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I doubt A new VFD is going to fix this problem.
    I would suspect something burnt out the original fuse and that problem is after the vfd in the circuit
    something exceeded it's rating like too large of a load or a short prior to the smoke fuse being installed.
    Steve
Share This Page
