    Dismiss Notice
Steel Building Info
Discussion in 'GENERAL DISCUSSIONS' started by mike silvia, Dec 27, 2016.
  1. mike silvia
    mike silvia United States Active Member Active Member
    3
    8
    City:
    westport
    State:
    Massachusetts
    -Return to Top-
    Hi Guys
    I'm in the process of looking for a steel building to put up for my garage/shop. I'm looking for a decent building for a lowish price. Gonna have some machine shop equipment in it and a lift for my cars. There are a bunch of companies out there and they seem like used car salesmen so I figured I'd ask for some real life experiences. Shop will be going up in SE Massachusetts so I'd also like to ask about if and how you insulated your buildings
    Thanks for any input
  2. firestopper
    firestopper H-M Supporter - Premium Content H-M Supporter-Premium
    1,390
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    I have a Mueller Inc. building. Not sure if they service Ma. but give them a call.
    mike silvia likes this.
  3. Nels
    Nels United States Founder Staff Member H-M Supporter-Premium
    788
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
  4. Reeltor
    Reeltor United States Active User Active Member
    260
    63
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    My daughter bought a quanset hut style building from Steelmaster
    http://www.steelmasterusa.com/lp/cl...act,S:Google&gclid=CMv5wPzIl9ECFRc6gQodmtwN7A
    From what I've seen, you can get a pretty good discount off of the published price and free shipping. My daughter doesn't have the building totally up yet; apparently they screwed up and need to pull some of the arches down and reset them. I guess that is what happens when you are 4+ hours from your building site and have friends help assemble a building. I think it's pretty good quality.
    Mike
  5. mike silvia
    3
    8
    City:
    westport
    State:
    Massachusetts
    -Return to Top-
    with this style I'm just worried about how I'm going to insulate it
    Thanks
  6. Nels
    788
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    You could adhesive panels of the pink insulation boards to the inside, or use firring strips. You could frame the inside to accept insulation .
  7. Reeltor
    260
    63
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    Nels posted while I was writing this; I think you would have the same issues with any steel building. You could use fiberglass batts with wire spring type holders, the manufacturer can explain your options. I would think any of the manufacturers would do the same.
  8. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    421
    63
    Mile High Colorado
    City:
    Center of Colorado 5420ft
    State:
    Colorado
    -Return to Top-
    Spray on foam insulation??
    firestopper likes this.
  9. firestopper
    1,390
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    R-30 insulation with scrim sheet (fiber reinforced ) held in with clips and wire 12" OC. Not sure if it would work on a Quonset hut style building due to lack of red iron. I would google snow load on Quonset style building as many have collapsed under load. I'm assuming MA gets plenty of snow. Most steel building companies offer a 3" insulation that gets sandwiched between the skins and red iron. I opted out of this and upgraded to 10" thick batts.
    4gsr, mike silvia and MonkMan like this.
  10. NCjeeper
    NCjeeper United States H-M Supporter - Premium Content H-M Supporter-Premium
    545
    93
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Yep. That's what I did on mine. I paid for 2"-3" but its a lot thicker than that in most places.
  11. Subwayrocket
    Subwayrocket United States H-M Supporter - Premium Content H-M Supporter-Premium
    281
    63
    City:
    Scranton/Wilkes-Barre
    State:
    Pennsylvania
    -Return to Top-
    Spray foam is worth the money. My buddy foamed my shop, it's 20x20 , my undersized heater barely runs even when it's been down around zero . There's about 2-3" of closed cell in the walls and and 6-7" in the rafters .
    If you go foam , get the closed cell type. It cost's a little more but it's worth it .
  12. Reeltor
    260
    63
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    Nice looking shop! If you don't mind me asking, what did you pay for the spray foam? did you go with open or closed cell foam? The recommendations were to use closed cell when possible but now the opinions are use open cell to know when a leak occurs and the water won't be trapped between the roof and the foam.
    Foam is the way to go if it's in the budget, is the pricing coming down?
    Mike
  13. oldboy1950
    oldboy1950 Active Member Active Member
    74
    28
    City:
    rochester
    State:
    Massachusetts
    -Return to Top-
    Morton buildings, a friend had one put up and he is very happy with it.
  14. NCjeeper
    545
    93
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    The shop is 25x34 and I put it up in 2004/2005. Its Icynene foam and I paid $1400. Well worth it.
    http://www.icynene.com/en-us/about-us
  15. rdrasher
    rdrasher United States Active Member Active Member
    26
    18
    City:
    eustis
    State:
    Florida
    -Return to Top-
    I found my new (stored in a container for a few years but never assembled) 24'x36' red iron steel building on CL for cheap.
    I'm in central Florida, so I opted for closed cell spray foam insulation and central A/C.
    Keep an eye out on Craigslist. Sometimes you can find a nice building for a really good price if you are willing to take it down and remove it.
  16. rdrasher
    26
    18
    City:
    eustis
    State:
    Florida
    -Return to Top-
    If you get spray foam insulation, be careful and make sure you check the foam thickness after it expands. I didn't and found out that it was "thin" in numerous places when the A/C installer cut away the foam to run a drain outside. So I called the foam company and made them come back out and respray everything they did. It was supposed to be 2"-3".
    NCjeeper, firestopper and mike silvia like this.
  17. mike silvia
    3
    8
    City:
    westport
    State:
    Massachusetts
    -Return to Top-
    anybody deal with or know somebody who has one from american steel?
Share This Page
