Stringy Chips and Bird's Nests: How to Pick the Right Chipbreaker
BeyondMachining
Technical Director - OYYU Tools
H-M Supporter - Commercial Member
Nothing ruins a good turning pass faster than a long, dangerous nest of stringy chips wrapping around your workpiece or tool post. Besides being a nightmare to clean up, those razor-sharp bird's nests leave nasty scratches on your finished surface.
If you are getting continuous stringy ribbon chips instead of nice C-shaped or comma-shaped chips, it usually boils down to three things: speed, feed, or the wrong chipbreaker geometry for your cut depth.
Here is a quick look at how chipbreakers actually work and how to pick the right one:
How a chipbreaker worksA chipbreaker isn't just a groove cut into the insert for looks. It forces the hot metal chip to curl tightly back onto the uncut workpiece material or the insert face until the internal stress snaps the chip into short pieces.
Matching chipbreakers to your cut depth
  • Finishing Chipbreakers (e.g., FN, SF, or similar light ground geometries):These have a narrow groove and a sharp raised ridge very close to the cutting edge. They are designed to force thin, light chips (under 0.5mm / 0.020" DOC) to curl and break. If you use a medium chipbreaker for a 0.2mm finishing pass, the chip just glides right over the groove without breaking.
  • General / Medium Chipbreakers (e.g., PM, MG, or standard molded geometries):These are the bread and butter for everyday job shop turning (1.0mm to 3.0mm DOC). The groove is wider to handle medium chip thickness without clogging or overheating the edge.
  • Roughing Chipbreakers (e.g., PR, GH, or heavy land geometries):These have a wide, reinforced cutting edge designed to handle heavy stock removal and interrupted cuts. Trying to use a roughing chipbreaker for light cuts will instantly produce long stringy ribbons.
Quick fix if your chips won't breakIf you can't change the insert right away, the fastest way to get short chips is to increase your feed rate. Pushing the tool a bit faster increases chip thickness, making the metal stiffer and much easier for the insert groove to snap.
How do you guys usually handle tough materials like 304 stainless when they refuse to break chips on light passes? Do you bump up feed rate, or switch to a dedicated positive sharp geometry?
(If you're stocking up on inserts with different chipbreaker styles or need high-rigidity tool holders, feel free to check out our lathe setup at www.cnchome-beyond.com.)
@Stick-man I think this thread needs the CHIP DESTROYER inserts with the mother of all chip breakers. Can you post, I'm busy getting ready to haul ass down to California.
Safe travels on the trip down to California!
If someone actually invents a true "Chip Destroyer" insert that breaks stringy 304 chips on a 0.002" pass without burning up, they'll be rich overnight!
Enjoy the drive down south!
DESTROY ALL CHIPS!
The chips will fly like fireworks on the Fourth of July!!!
They also come in DNMS.
For steel I also have an Iscar holder that uses CNMX, and they fly just like the one above.
@Stick-man Flying like 4th of July fireworks is the absolute best way to describe good chip control!
Those CNMX and DNMS geometries are no joke—that high-rake helical edge design really forces even stubborn steel to snap into tight little 6s and 9s instead of wrapping around the toolpost.
Appreciate you dropping the catalog link for everyone here!
@coolidge Now THAT looks like a true chip terminator!
Those Iscar geometries look intense—the raised ridges on those look like they could break chips off stock even if you forgot to turn the lathe on.
Definitely putting those under the "Chip Destroyer" category!
There was a discussion on another forum where we were all complaining about the long stringy aluminum/stainless chips and this guy chimes in with this chip destroyer insert suggestion.
So I gave them a try, holy crap small chips were flying all over the place I was getting pelted while laughing and thinking I need to fab some chip guards. :D
@coolidge Getting pelted by hot little chips while laughing is definitely a rite of passage!
Honestly though, taking a few stray chips to the shirt is a million times better than having a razor-sharp bird's nest whipping around the chuck. Time to break out the polycarbonate sheet and fab up a proper chip guard!
