What I like most, you can put it up in a drawer.+1 on Tony's thoughts about thin glass. For grins, I mic'd a small 6x8 pane and it was off several thou from end to end. Optical quality glass is probably dead-on but would cost about as much as a B-grade slab -I'd go for the slab and a B-grade is cut better than anyone in a home shop could dream of measuring (something like +/- 0.00005"). The granite at Shars is pretty inexpensive but shipping (naturally) is costly due to weight.
As far as they go, I never thought I'd use one much but it ends-up getting used a lot...
So let me make sure I get this. There are two considerations for a plate. The first of course is a truly flat surface. Not eye the edge flat like determining if a 2x4 is twistd, but measured flat to some Nth degree. The second consideration is how thick it is. My assumption here is, the thicker the better. Thicker means less flex, less movement, and less plasticity/flow.
am I correct?
am I missing anything?
so back to point, on OP, would a sink cut-out from a thick granite counter top be a good starting place?
