Thoughts of building a CNC router table
Hey Everyone,
Thanks for all the input...
First off, as to the mechanics of what I'm building, I listened closely to all you who implied that Acme was not acceptable,
but sorry, common sense wins out.
If you have ever done metal machining, think about every mill or lathe you have ever used..
Acme screws, and we try to hold a .001" or better tolerance.
Now I'm looking at a router for wood parts that will get glued together, do I really care if I have .005-.01 tolerance?
And lordy knows the issues I've have with ball screw systems in the past..
Think about a 1/2-10 Acme, 1/10 inch travel per revolution/200 steps per revolution (typical stepper),
equals .0005" step resolution.. I know that does not take into account mechanical play, but..
Second, I've been looking at controller suggestions y'all are giving.
I really like what I see in the Centroid system, lots of options (including backlash compensation),
and the ability to have PC based HMI comtrols.
That DDCSV3.1 controller I mentioned in my first post seems like a good second.
I've looked at other stuff, but as I originally pointed out, "Old & Retired", which equates to limited budget.
Now the one key aspect I'm seeing on any controller system, seems to be that magic missing link,
I have CAD, I can export DXF.. But that doesn't give me acceptable input to CNC control.
Now I need DXF to G-code (with tool path) conversion..
I've played with a few trials, but in the end, they all want some of your money..
Carbide Create woks nice, but you gotta buy it to save the g-code..
Someone suggested Fusion360, similar results..
A good smattering of "free online conversions" with limited options..
Any good suggestions here?
Again, Old & Retired, I can't afford annual license fees of $120 - $500 just to play in my workshop..
JohnR
The major differentiating feature between Acme lead screws and ball screws is that ball screws have negligible backlash, This matters because when there's a direction change the backlash will show in your cut. Yes, I know that most CNC control systems will have backlash compensation but it is never good enough to eliminate the artifacts backlash leaves behind.
Import ball screws are so cheap now I would never compromise and use an Acme lead screw instead.
I'll repeat what I said above: if you want a really, really good controller that won't break the bank, just works and is well supported buy a Super Longboard from Sienci.
Fusion is free for hobbyists and works great.
Acme is not as you think .001 tolerance.
And I did not say it was...
I said we use Acme on machine tools every day where we expect to get .001 tolerance.
But enough of the mechanics for now, my last questions related to controllers and magic conversion software.
Anyone have thoughts on that?
But, now we get to my lack of experience, the servo controls.
It's not just experience with the controls, its experience managing 3D motion control including the hardware that controls/constrains the 3D motion. On acme vs ball screw, there are anti backlash nuts but in general, they tend to be very light duty and typically not applicable to anything accept printers. What it really comes down to is the difference in cost of the entire project to have the accuracy of ball screw vs acme. It's a small difference in total cost and a large difference in performance of the machine. If you're expecting a result anything near what your friend hands you back from his full blown machine, you're kidding yourself.
There are many other things that contribute to the accuracy and performance of the machine, such as the lead screw thrust blocks, the linear guidance system, and general rigidity of the structure. It all adds up. In the video I posted earlier, I converted from V-wheels to linear rails and bearings.....there was a reason for that........accuracy/rigidity.
The great thing about advice is, you don't have to accept it. But if you are uncertain enough (or in this case certain enough ;) ) to post, why bother asking?
Secondly, I'm assuming that I can use a conversion software, to turn a CAD vector file (DXF/DWG) into G-Code.
Anyone have hints/tricks for doing this?
You mentioned giving your friend a CAD file. I don't know how versed you are in the CAM side of the things but based upon this question, sounds like none. That's fine and it depends upon your starting point experience wise, but there can be quite the learning curve depending upon the type of work you want to do. Once you learn the CAM program, it will have a post processor that spits GCode. You will still want to have at least basic working knowledge of GCode. Having a CNC router is one thing. Knowing how to use it can be another. Cutting 2D profiles in wood sheet is pretty basic work, but like anything else, there is a big difference between reading/watching about something versus actually doing it yourself. For me, it was well worth the effort, but the effort was not trivial.
Best,
Kelly
first off i agree with you and lead screws will work (and do all the time) but your analysis is flawed, manual machines use lead screws but a large part of manual machining involves compensating for backlash, you always turn into you dimension in the same direction, go past the point and back to it to eliminate backlash. there are compensations that can be used in cam software but they are problematic. you also CANNOT use climb milling if you have excessive backlash. for what you are stating you want to do you should be able to overcome this limitation but it will be a limitation of your system.
For what you have identified as your use, leads screws will most likely get you there and if they don't and you have to upgrade later it is a 1 for 1 swap and is not the end of the world, also you will have gained experience with the controllers, software and tooling by that point so you will be better able to decide what you want.
Fusion 360 IS FREE TO USE as an hobbyist, not all of it but enough to do what you want to do for now. Fusion 360 is a powerful software system and as such is more complicated than other things that are more geared to hobbyists but IMO is well worth the effort to learn.
anyway, good luck with your project.
Yes, I haven't been here in a while, more of a "do-er" than a "talker"...
I took some advise and changed my design to linear rails and ball screws, found some cheap packages on ebay,
getting close to finishing the mechanics, and looking ahead at my controls.
I decided to try the DDCS 4.1 but with bigger steppers (and please, let's not all chime in with opinions of my decision in controllers, just looking for someone with experience with the DDCS for some insight).
I've been studying the manual, at this point looking at first steps (axis config).
And of course there is some confusing context (probably rooted in translation to English).
I have to input the Numerator and Denominator for each axis, and the manual spells out;
"Numerator: The number of pulses required for one revolution in one direction; Denominator: The feeding distance the
motor moves one revolution in one direction. The pulse equivalent = numerator /denominator".
Ok, for my Numerator, I enter my steps per rev. of my stepper (I'll start with the default of 200).
But, for the entry of the Denominator, the description on the line says;
"X axis pulse equivalency(denominator)", with a range of 1.000 ~ 99999.999
So, am I entering the travel distance (5mm) here, or doing the math, pulse equivalent = numerator /denominator,
200/5=40, and entering 40 here?
And to add to my confusion, I've set the system units to Inches, so then; 200/0.1968498=1016.003 ??
Anyone have experience with the DDCS controller?
Regards,
JohnR
You won't regret changing to rails and ball screws.
Regards,
JohnR
take your time and step thru it you will get there, good decision on the ball screws and rails. I have not used the DDCS 4.1 or the 3.?? either but i have researched them and they look like a lot of bang for the buck. the outcome will depend on your skill most likely as i do not see much that the DDCS will not support, I was looking at encoder feedback for my project and it will not do that but you do not need it.
Good luck and please post photos as you go along.
I second the request for photos.
Sent from my iPhone using Tapatalk Pro
