Thoughts of building a CNC router table
Well here's what I have assembled so far, like I said, old, retired, limited "fun money".
I'll get some more photos happening soon, after it starts looking like something..
I have a lot of parts made, but as with most one-off projects I'm designing as I go.
"Waiting for a part for this so I can measure for that"...
Most of it is in my head, but I will make detailed CAD drawings of parts that I have to drill,
print it out to scale, tape it to my piece, center punch the crosshairs, use a brad-point 1/8" bit
to drill a pilot hole, then drill to size, keeps things pretty accurate...IMG_20251127_160450_HDR.jpg
The gantry side plates look to be about 1/4". You might find that you have a fair bit of lateral flex in the X axis because they lack sufficient rigidity.
Is there a reason why you have so much Z axis clearance?
Gantry sides are awaiting some "stiffeners", and another cross brace (again, work in progress).
Z axis clearance; Two layers of 3/4 MDF will sit on top of the frame, and my Z assembly hangs a bit below the shown plate.
Will end up with about 4 inches of clearance..
I was asked for some photos of my progress, never said this was the final assembly..
to drill a pilot hole, then drill to size, keeps things pretty accurate...View attachment 554939
Looks like a good start
I originally went with a router as a spindle but quickly designed and built a spindle with vfd. R8 collets
Mike, can you elaborate on the spindle you built, pics or drawings?
I'm starting out with a router, but that's just so I have one less thing to build while trying to get this table together, plan on upgrading later..
JohnR
Following.
@stagekraft From your username are you IATSE?
I'm not but have a long background in AV and IT. I have a large steel plate and am considering a build like yours but with the rigidity of a 500lb+ base to start.
John
JohnR
John, I machined the spindle for r8 collets but pretty much use the er32 collets and adapter. 1 hp motor and vfd. I initially thought it would be too much weight for the z axis but that is not the case. I have been running this thing for 5 plus years with no issue.
On the initial build, I used mostly scrounged up 8020 solid web aluminum extrusion and a bunch of other obsoleted parts. Rigidity is a big deal when you start to push the speeds and feeds along with cutting aluminum. I don’t push the machine. It’s pretty happy with rapid speeds at 150 ipm. I just did a job , 1/2” aluminum plate, 1/2” diameter 2 flute. Cuts all day long!
I got a few of the spindle assemblies as depicted in the pics. You will need to make a spindle of your choice but this is a good start for you. Pay shipping and I will donate to your cause!
View attachment 78664251508__0FCE311B-968C-40FF-AA5F-93227AB99AD8.MOVimage.jpg
No, I am not in the stagehand union, but I started doing concert sound back in the late 70's (D-Hi Sound, Don Hartwig), and worked for a then prominent sound equipment manufacturer designing/building electronics and speaker systems (Heil Sound, Marissa Il).
Stagekraft is the name of my hobby business I've been using since the early 80's.
I'm still dabbling, mostly for friends and local clientele.
The main reason for build the CNC (along with my passion for designing/building) is to do away with the drudgery of hand routing speaker cabinet parts with templates..
JohnR
Mike, I'll give that some consideration when I get a little further along.
Thanks,
JohnR
