- Nov 16, 2012
- 5,596
Still confused... Help me here... Obviously, if you hit it with a torch, you're not holding it in your fingers. When you take it to a grinding wheel, I presume (but maybe I'm wrong) you still hold it by hand. Unless you got asbestos fingers, you can only hold the thing for so long before your brain figures-out "This thing is hot!".
If I'm touching-up a bit, it takes all of 5 seconds -no problem. If I'm making a bit from a blank, it needs a lot of grinding and will get too hot to hold (and I don't use gloves near a grinding wheel). So, I would have to grind until uncomfortably hot, let it cool, go at it again -yadda. Heck with that. Dunk it cold -really cold. Then, it takes a long time before it gets uncomfortable again and you get more grinding time.
Side note: My father could hold bits until his fingers literally smoked a little but I don't he noticed it. -Pretty sure he had asbestos fingers...
Anyhow, my Hanser book is at work (lunchtime reading of course) and I'll try to get the skinny on HSS annealing temps.
I'll give you an extreme example. I wanted a 2.000 radius slab tool. I had a piece of 1" HSS. I took a oxy acetylene torch and burned it in according to a scribed line, then took it to a 10" 36 grit OA wheel to get it close to profile. Then I used another trick (to be given at some later date) to finish the radius with a smaller grinder. Never touched water with the tool. Never had a problem cutting 4140 @36 Rc.
