Turning Aluminum: Why Steel Inserts Fail & Choosing the Right Uncoated Geometry
BeyondMachining
Technical Director - OYYU Tools
H-M Supporter - Commercial Member
If you've ever tried turning 6061 or 7075 aluminum with a standard steel-cutting carbide insert, you've probably seen the results: long ribbon chips, a torn surface finish, and a big lump of metal welded to your cutting edge.
Steel inserts usually rely on thick PVD or CVD coatings and moderate edge hone (a rounded cutting edge) to withstand heat and high cutting pressures. But on soft, ductile materials like aluminum, copper, or brass, that rounded edge acts more like a plow than a knife.
Here is a quick breakdown of why dedicated aluminum geometries make such a massive difference in your shop:
1. The "Razor-Sharp" Ground Edge (AK / AL / H01 Geometries)
  • The difference: Dedicated aluminum inserts (like CCGT or DCGT instead of CCMT/DCMT) feature precision-ground, un-honed cutting edges.
  • The benefit: The ultra-sharp edge shears soft non-ferrous metals cleanly rather than pushing or smearing the material, which drastically reduces cutting temperature and prevents chatter on small lathes.
2. Mirror-Polished Top Face
  • The difference: The top rake face of an aluminum insert is polished to a mirror finish.
  • The benefit: Aluminum is notoriously "sticky" when hot. The mirror surface gives the chip zero friction to grab onto, virtually eliminating Built-up Edge (BUE) and keeping your tool tip clean.
3. High-Rake Chipbreaker Design
  • The difference: Deep, steep rake angles force soft, pliable aluminum chips to curl tightly and snap rather than forming long, dangerous bird's nests that wrap around your chuck.
When should you still use uncoated/polished inserts?Besides aluminum, these polished CCGT/DCGT inserts are absolute lifactors for plastics (Delrin, Acrylic), brass, copper, and even taking micro-finishing passes on mild steel when you need a mirror-like surface.
Do you guys keep a dedicated set of CCGT/DCGT holders loaded for non-ferrous jobs, or do you just push speed and feed with general-purpose inserts?
(If you are looking to restock on precision-ground CCGT/DCGT aluminum inserts or high-rigidity tool holders, feel free to check out our lineup at www.cnchome-beyond.com.)
You can save a lot of money and learn a new skill by creating your own cutting tools from HSS blanks. I'm still using cutting tools I ground back in the 1980's. Others were inherited from my wife's father and grandfather. They've been reground dozens of times and still work fine today. It's hard to justify a $15.00 to $25.00 insert with only 4 cutting edges when a $20.00 HSS blank can be reground a hundred times and last a lifetime.
As a side note I was buying boxes of HSS blanks when they were in disfavor. They usually ran $.50 a piece or $35.00 for a box of 70 and $25.00 for a box of 50. I was able to buy a lifetime supply for less than $200.00. Now I don't have to repurpose form tools every time I need a new one.
For aluminum, plastics and wood I use dedicated xxGx holders. If I can't get a job done using xxMx inserts or ground HSS, I use a xxGx type insert as last resort. Most of the time that gives a good result even on stainless.
Cheap AliExpress inserts are my preferred tools but for some jobs I prefer HSS tools.
I can regrind a HSS tool faster than changing an insert.
I know, I spend far more money on inserts than on HSS tools. But on the CNC lathe, having a known tool offset is important for me.
@projectnut Hard to beat the economics of a good HSS blank, especially when you can grind whatever front and back clearance or custom radius you need on the bench grinder. Passing those tools down through three generations is awesome!
You're completely right about aluminum—a properly hand-ground HSS tool with a steep top rake and polished stone edge will leave a razor-clean finish on soft materials that rivals any carbide insert.
Carbide definitely takes over when you need to bump up the surface footage (SFM) or run batch jobs without stopping to re-sharpen, but for custom profiles and low-speed manual turning, HSS is still king.
@Huub Buis Using ground xxGx (CCGT/DCGT) inserts as a secret weapon on stainless is a great move. When you're taking a light finishing pass on 304, that razor-sharp un-honed edge shears the metal before it can work-harden, where a heavier xxMx insert might just push and rub.
And you hit the nail on the head regarding CNC offset repeatability. Being able to just swap a worn carbide insert for a fresh corner in 30 seconds without having to re-touch off your X and Z tool offsets on the controller is priceless.
After an insert swap, I do not check the Z tool offset. The X tool offset is most of the time a bit (0.025 mm ; 0.001") off so that needs to be adjusted. So after the first finish pass, the diameter is measured and the tool offset is adjusted. After regrind of a HSS tool, I do the same.
@Huub Buis That 0.001" (0.025mm) X-axis shift is super real! Even with quality indexable inserts, the manufacturing tolerance on the IC (Inscribed Circle) and nose radius will almost always sneak in a thousands or half-a-thou error on diameter.
Taking a quick spring/finish pass and touching up the X wear offset on the controller is definitely best practice for tight tolerance work.
The big beauty of carbide is knowing that X shift is only going to be around 0.001" instead of 0.030"+ like after re-grinding a blank!
