Using A Er32 Or Er40 In A Bridgeport Mill R8 Collet
Ed ke6bnl
Nov 20, 2014
755
Why don't we ever see any mills using an ER32 or ER40 to R8 tool holder??? I can see one possible disadvantage of the ER as having a little more stick out, but not necessary to reach to the top to release the R8 collets. I was thinking of going to this system. Whats ya think
Are you referring to an ER chuck with an integrated R8 shank? If so, they work fine. I have an ETM ER-40 chuck like that and an ER-32 chuck that fits Tormach's TTS system. Both work well. The ER-32 slips out of the TTS 3/4" R8 holder easier for bit changes. The ETM one requires a spindle wrench up top to hold the spindle still while I loosen and tighten the ER chuck nut down below. Its a bit more cumbersome but the chuck and ETM collets are really accurate.
ETM is a brand of collet and collet holder? yes I was refering to the ER collet with the intigrated R8
Sent from my SM-G930V using Tapatalk
Yeah, ETM is a brand, a pretty accurate one and is part of the Iscar line of companies. Watch Ebay. They come up for stupid cheap on occasion. The only issue I have is that sometimes they do chew up a bit of Z-space so on a tall project an R8 collet is more useful.
Otherwise, I like ER chucks on the mill. They are versatile and pretty accurate. You don't realize how important that is until you have to cut a woodruff keyseat; use an inaccurate collet/chuck and you get a slip fit instead of an interference fit.
I had just started thinking about this. I got an ER32 collet chuck for my Diamond horizontal mill so I don't have to reach around behind it and pound the drawbar out every time. But now that I have some collets, I'm thinking of getting a collet chuck for the Bridgeport too. Using z-space actually doesn't bother me much, because I like the idea of being able to switch between my 14N and the ER chuck between ops and not have to raise or lower the table like 5 inches.
I'd like to hear more arguments for why I should get one :D
Just a word of caution
when using a ER collet chuck on a mill the cutter can work itself out of the collet creating a neat ramped cut in your work.
I had this to happen two times, The first time While cutting a key slot in a shaft I figured that I did something wrong, after that I always made sure that the collet and cutter was clean and the nut was tight. But after the second time I decided that enough is enough and stopped using ER collets. Now I only use dedicated holders and tooling with the flat on them. For me its easier to knock the draw bar out than make a new part.
If you have Ever wondered why you occasionally see a neat ramped cut in milling tables and think how someone could do that, now you know. I haven't done that but I came close :(
Is there a ER collet nut that uses something like a thrust bearing so it is easier to tighten and therefore will hold tighter for the same tightening force
Yup, there are nuts exactly like that. https://www.maritool.com/tool-holde...437/er32-bearing-collet-nut/product_info.html
I have some from ArcEuro Trade and they work fine for most stuff. When I need to make a really accurate cut I use a hardened nut from ETM and torque it down. I didn't think it made much of a difference until I was troubleshooting why my woodruff keyseat cutter was producing a slip fit instead of an interference fit. Turns out that my collet and nut were not up to the task. Switching to my ETM collet and nut did the trick.
