My home garage shop is really tight (who's isn't - right?). I don't really have a good place to store metal stock. So I was looking around for some place I could use. I have a big I-beam that runs the length of my shop. So I got thinking about how I could use that, by making suspended brackets. I grabbed a yellow sticky and scribbled this idea out. It would be two pieces of 1/4" x 1" or 1.5" flat stock, bent and bolted together to suspend from the I-beam. I'm not talking about storing a LOT of stock, just maybe 50 lbs worth. I'd use a piece of all-thread just below the beam with nuts on each side of the flat bar to lock it in place. Then use a bolt vertically through the two pieces at the bottom to hold it together. I could weld maybe 4 tabs along the bottom to use as dividers to keep things organized a little. I'd probably make 3 or 4 of them.
Here's my yellow sticky drawing. What do you think? Trying to keep it as simple as possible. Thanks, appreciate your thoughts.
