Clausing Lathe Model 100 Mk3 Gear Train Cover
DanLins
Measurer
Sep 30, 2011
25
Gunrunner you need to order a set of these for the Z axis hand crank. Bill did you just spit coffee on your monitor? :rofl:
A gentleman from Los Altos, California was kind enough to donate his gear train to me. Lotsa nice folks participate in these forums.....
Dan L
Did you get everything that you were looking for?
Robert,
Yep, everything except the wide 75 tooth gear that drives the shaft to the QC gearbox. My brother and I are going to make this gear.
The only other thing missing is the gear train shroud, which may be impossible to locate.
Thanks,
Dan L
OK. I would suggest that you set up a daily search for the remaining two items on eBay and just let it run until you acquire one elsewhere or until you get a valid hit. I've turned up quite a few obscure items that way over the years. I also edited the title to what you are still missing.
Thanks, Robert. I really don't need that wide 75 tooth gear however. I'll try your eBay search, see what happens.
Dan L
OK. I'll take it off.
