Why Does My Carbide Insert Chip? 7 Common Causes and How to Fix Them
Why Does My Carbide Insert Chip? 7 Common Causes and How to Fix Them​
Carbide inserts are designed to handle high cutting temperatures and maintain their cutting edge much longer than conventional high-speed steel tools. But many machinists eventually run into the same frustrating problem:
The insert starts chipping, cracking, or breaking long before it should.
The first reaction is often to blame the insert itself. Sometimes that is the problem, but in many cases, insert chipping is caused by the machine setup, cutting parameters, workholding, or using the wrong insert geometry for the job.
Here are seven common causes of carbide insert failure and what you can do about them.
1. The Cutting Edge Is Not Actually Cutting​
One of the most common problems is running carbide with too little feed or too little depth of cut.
Instead of cutting properly, the insert may rub against the workpiece. This creates heat and friction around the cutting edge. Eventually, the edge can chip or break down.
This is especially common with small machines when the operator is trying to be overly cautious.
What to check:​
  • Is the feed rate too low?
  • Is the depth of cut smaller than the insert's effective cutting edge radius?
  • Is the insert designed for finishing, but being used for roughing?
A light finishing insert may not perform well if it is repeatedly forced into interrupted or heavy cuts.
Fix: Use a suitable feed and depth of cut for the insert geometry. Let the cutting edge actually engage the material instead of rubbing.
2. Too Much Tool Overhang​
Tool overhang is one of the biggest causes of vibration.
When using a boring bar, the problem becomes even more obvious. A long boring bar can flex during cutting, creating chatter. Every vibration cycle puts additional stress on the carbide edge.
Carbide is extremely hard, but it is not as forgiving as HSS when subjected to repeated impact.
Common symptoms:​
  • Random edge chipping
  • Poor surface finish
  • A repeating vibration pattern on the workpiece
  • Loud chatter during cutting
Fix: Keep the toolholder or boring bar as short and rigid as possible.
For boring operations, extend the bar only as far as necessary to reach the required depth.
A larger-diameter boring bar will usually provide better rigidity than a smaller one with the same overhang.
3. The Insert Grade Is Wrong for the Material​
Not all carbide inserts are designed for the same materials.
An insert that performs well on mild steel may not last long when machining stainless steel, hardened material, cast iron, or heat-resistant alloys.
The carbide substrate, coating, edge preparation, and chipbreaker all affect performance.
For example:
  • Steel: General-purpose coated carbide is commonly used.
  • Stainless steel: Usually requires a tougher grade with good resistance to built-up edge and heat.
  • Cast iron: Often benefits from wear-resistant grades.
  • Aluminum: Sharp, polished cutting edges generally work better.
  • Hardened steel: May require specialized carbide, ceramic, or CBN tooling.
Fix: Select the insert grade for the workpiece material, not just the insert shape and size.
A CNMG120408 insert from one grade may perform completely differently from the same insert geometry in another grade.
4. Interrupted Cuts Are Hitting the Edge Too Hard​
Interrupted cutting is much harder on carbide than continuous turning.
Examples include:
  • Turning keyways
  • Machining castings with interrupted surfaces
  • Removing weld buildup
  • Cutting parts with cross holes
  • Machining hexagonal or irregular stock
Every time the insert enters and exits the cut, the cutting edge receives an impact.
A sharp finishing-grade insert may chip quickly under these conditions.
Better approach:​
Use:
  • A tougher carbide grade
  • A stronger edge preparation
  • A suitable negative-rake insert when machine rigidity allows
  • More stable workholding
Fix: Do not automatically use the sharpest insert available. A stronger cutting edge may survive interrupted cutting much better.
5. The Insert Is Installed Incorrectly​
Even a good insert can fail if it is not seated properly.
Before installing a new insert, always check the insert pocket.
Small chips or dirt trapped underneath the insert can prevent it from sitting flat. This can cause movement during machining.
Overtightening the clamp screw can also create problems, especially on smaller inserts.
Check:​
  • The insert pocket is clean
  • The insert sits flat
  • The clamp or screw is in good condition
  • The correct screw is being used
  • The insert is not damaged before installation
Fix: Clean the pocket every time you change an insert. It only takes a few seconds and can prevent expensive insert breakage.
6. Cutting Speed Is Too High​
Excessive cutting speed generates more heat at the cutting edge.
Depending on the material and insert grade, this can cause:
  • Edge wear
  • Thermal cracking
  • Plastic deformation
  • Rapid chipping
This is particularly important when machining stainless steel and other materials that retain heat.
On hobby machines, machinists sometimes use recommended speeds from industrial production data without considering machine rigidity or setup stability.
A production CNC lathe with high horsepower and excellent rigidity can run the same insert under conditions that a smaller machine cannot maintain.
Fix: Start with conservative cutting parameters and increase speed gradually while monitoring wear and surface finish.
The goal is not simply to run the highest possible RPM. The goal is stable, predictable machining.
7. Machine Rigidity and Workholding Are Not Stable​
Sometimes the insert is not the real problem at all.
The workpiece may be moving.
Common causes include:
  • Part extending too far from the chuck
  • Loose workholding
  • Worn machine bearings
  • Insufficient tailstock support
  • Flexible toolpost or toolholder setup
When the workpiece moves during cutting, the carbide edge can experience sudden changes in cutting load.
This is particularly damaging during roughing.
Fix: Improve the overall rigidity of the setup before changing inserts.
Support long parts when possible, minimize workpiece extension, and make sure the toolholder is clamped securely.
A Quick Troubleshooting Guide​
ProblemPossible CauseFirst Thing to Check
Small chips on cutting edgeVibrationTool overhang and machine rigidity
Large chunks breaking awayInterrupted cut or excessive loadInsert grade and cutting conditions
Edge wears very quicklyIncorrect speed or material gradeCutting speed and insert grade
Random insert breakagePoor seating or vibrationInsert pocket and clamping
Poor finish before insert failsChatter or built-up edgeRigidity and insert geometry
One Important Point: A More Expensive Insert Is Not Always the Solution​
When an insert starts failing, it is tempting to replace it with a more expensive brand.
But if the real problem is chatter, excessive overhang, incorrect feed, or poor workholding, the new insert may fail in exactly the same way.
The best approach is to inspect the failed insert.
The wear pattern can often tell you what happened.
For example:
  • Chipping on the cutting edge may indicate vibration or impact.
  • Cratering on the top surface can indicate excessive temperature.
  • Uniform flank wear may simply mean normal tool life.
  • Built-up edge can indicate unsuitable speed or geometry.
Learning to read insert wear is one of the most useful skills for improving machining performance.
Final Thoughts​
Carbide inserts are strong, but they are not indestructible.
Most premature insert failures come down to one of four things:
Wrong insert + Wrong parameters + Poor rigidity + Unstable setup
Before blaming the insert, check the entire machining system.
A correctly selected insert, properly installed in a rigid toolholder and used with appropriate cutting parameters, can make a dramatic difference in tool life and surface finish.
For hobby and small-shop machinists, improving setup rigidity is often more effective than simply buying a more expensive insert.
What usually causes carbide insert chipping in your shop?
Is it vibration, interrupted cuts, the wrong cutting parameters, or something else?
I'd be interested to hear what other machinists have found to be the biggest cause.
