Parting off a finished piece is easily the most nerve-wracking operation on a lathe. You run a beautiful job, bring in the cutoff blade to separate the part, and suddenly you get deafening chatter, heavy burrs, or a broken carbide insert wedged deep inside the slot.
When a parting tool starts singing or hesitating, the knee-jerk reaction for many machinists is to slow down the feed rate.
Unfortunately, dropping your feed too low on a parting cut is the fastest way to wreck an insert. Carbide needs material resistance to form a proper chip. When you feed too light, the cutting edge rubs, friction builds massive heat, and the blade flexes sideways until it jams in the groove.
If you are fighting chatter, tapered cuts, or premature insert failure during grooving and parting, here is how to fix the mechanics of your setup:
1. Keep Your Center Height Dead-On (Or 0.002" High)
(If you are looking for rigid parting blocks, precision cutoff blades, or specialized GTN/MGMN grooving inserts with aggressive chipbreakers, feel free to check out our catalog at www.cnchome-beyond.com.)
- The Problem: If your cutoff blade is even slightly below center, the cutting force pulls the blade down and under the center of the bar, causing the tool to dig in and snap.
- The Solution: Use a dial indicator or height gauge to set your parting edge dead-on center. If in doubt, erring 0.001" to 0.002" above center is far safer than running below.
- Extend the parting blade or block only as far as necessary to clear the bar radius (plus 1mm to 2mm for chip clearance). Every extra millimeter of unnecessary overhang drastically reduces blade rigidity and invites chatter.
- Once the blade enters the cut, maintain a steady, continuous feed rate (typically 0.002" to 0.005" per rev, depending on material). A firm feed keeps the insert cutting underneath the work-hardened layer and produces clean, continuous chips that push straight out of the slot.
- If your cut tapers toward the part face or leaves a concave bottom, your block is not square to the spindle centerline. Even a 0.5-degree angle misalignment causes the side of the insert to rub against the slot wall, generating massive heat and binding.
