X2 Mini Mill CNC Conversion?
oh dahhh i hit the back button and had to start over
cnc4pc.com items
e-stop
http://www.cnc4pc.com/Store/osc/product_info.php?products_id=138
limit switches 6
http://www.cnc4pc.com/Store/osc/product_info.php?products_id=79
fan(s) depends on your enclosure get everything first
http://www.cnc4pc.com/Store/osc/product_info.php?products_id=374
plugs and sockets not required but nice addition if you go for it get 4 so your ready for 4th axis
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=29_88&products_id=439
ebay item
shielded wire 4 conductor it's in 10' lengths 4 would be nice so you have it for other wiring and 4th axis when your ready if not 3 will be fine
http://www.ebay.com/itm/CNC-Stepper-Motor-Hook-UP-WIRE-18-4-Buy10-increments-/290566475320?pt=LH_DefaultDomain_0&hash=item43a71c8e38
steve
cnc4pc.com items
e-stop
limit switches 6
ebay item
steve
Whats a good encloser to get is the one on there site good? if so do i need to but there panels ?
cnc4pc.com items
e-stop
limit switches 6
ebay item
steve
What about a power cord and recepticle
Will they build a ready to run setup with this kit? Thanks Mike
I don't know of anybody that builds a full kit with mechanical and electrical components "ready to run" for an X2. Most of the kits I have seen are ball screw/bracket kits, and you have to supply your own motors/drivers/power supply. Just make sure the motors are the right frame size for the kit you buy.
If you are just looking for the electrical package to be assembled, Keling doesn't do that, you can get something like that from flashcut as I recall (more $$), and it looks like probotix will put everything in a box for you, but looks like it is an extra charge.
The nice thing about the X2 is that so many people have done conversions that there is a ton of information out there.
If you go with the 4 conductor cable posted on that E-bay link it will not work with the probotix drivers as they are unipolar. Unipolar needs 6 wires. If you go with a bipolar driver you can use a 4 conductor.
Im not going to use the probotix drivers im ordering a kit on ebay
here are the videos this guy at hoss machine is good and speaks in laymans terms
one thing that needs to be said is check the voltage from the power supply they are adjustable I would do it before wiring anything and set all the switches on the cards. wire the cards and double check everything again before powering up. the card settings I can help with once you have them and their data sheets
I'll go look at the ebay item you posted and shop a bit for you what is your limit on cost for a set including power supply, controller(s), breakout board and motors give me a max and i'll help you find the most for the money
steve
I dont see any videos?
hey the video is missing I posted it i'll try again
http://www.hossmachine.info/Shop_Info.html#wiring cnc
for a power cord cabinet and plug do you have a way to get an old computer case they make good enclosures if they are real old the have an actual power switch also if not i'll look for more parts
steve
