- Feb 2, 2013
- 3,540
i purchased a set of inexpensive collet block's from all-industrial tool supply for use in my lathe and milling machines.
they were shipped fast and are very nicely finished, better than i thought i might get for the price.
i don't have any connection to the company, but i had a good experience and thought i'd say something about it.
the set came with 2 spanner nuts and a lever/cam closer, but didn't include the spanner wrench.
(the wrench was not pictured in the ebay store nor was reference made to the spanner wrench in the ebay store)
i didn't consider the wrench to be a deal breaker, the overall cost was under $50 shipped- i let it go.
my decision worked out for awhile, i used the lever/cam closer and was happy as a clam.
then i wanted to hold some 1" stock that was slightly under 1", .988" to be exact.
but there's another hitch, i needed a longer piece to pass through the collet and block for milling in the vise.
i figured i'd spring the 1" 5C collet a little and grip the material,
i didn't have the spanner.
so my project was to make a spanner.
i had some 2-1/2" 1018, and some 5/8 rod and some rod material for the pins
it was just as simple to make 2 at the same time, so i did!
i punched the center out to 1" and finished bored to 1.70" with a freshly resharpened cemented carbide boring bar
i cut the ring in half and shortened the halves by gang milling in the vertical mill
i had some 5/8" 304 shafting reclaimed from a machine,
and a piece of 5/8 hot rolled unknowinium- that didn't want to machine very well with carbide, so i switched to HSS
and it machined a bit better but was some pretty tough stuff
i made some pins from some hot rolled 3/16" stock and cut them at .345" long
i center drilled and tapped the newly formed handles to 1/4"-20, and drilled and tapped the wrench head to attach the handles
i drilled the pin holes undersize and reamed to .1870"- the pin has a light press fit.
i cut 1/4"-20 all thread studs and attached the wrench heads to the handles and used red locktite to bind the heads to the handles
and made final assessments
i swept the angle of the handle away from the flat plane to potentially save a knuckle or 2
they passed inspection
i took one for a test ride....
and the final shot
now i can go back and attempt to finish the project i originally set out to do.
it never seems to end.
make something to make something else work , or otherwise take another step forward on another project!
thanks for reading!!!
and the final shot
