- Mar 26, 2018
- 8,352
I think it's very rigid. They use 3/16 steel. You then tack weld during the build process. once you are sure the cross supports are flat with no light coming through between the table and the supports you finish welding it.
The 2" straps are laser cut, they have little fingers that come up through holes in the table. You weld these to the table and flap grind the filler nice and flat.
I am very impressed with the build quality. Did you watch the video?
The leg kit is made the same way, it has 2 slits in the legs that fit over the table supports so you get plenty of welding joints and the leg cross supports fit into pre-cut notches that weld up good and square/strong!
