I have used both methods and it depends on what you are planning to do.
Blasting requires immediate preparation and at the least priming or the metal will have surface rust again in a couple of days. I found even overnight I had surface rust on components after blasting.
When I resprayed my car (bare metal respray) I used rust converter on surface rust. It turns it black and provides a protective layer to prevent further rusting.
I have also oil dipped metal to prevent rust. I did this on my surface plate feet. Heat them before dull red and plunge into an oil bath. Just be careful as the oil can sometimes flash, and you will lose an eyebrow, (don't ask how I know that)..........
