I used 1/2 dot truck air brake line because I had a spool of it and a whole bunch of swivel type push lock fittings. Is basically the same system the OP shows but not in a kit. Was super easy to run and add on as you want. It's been installed for about 10yrs and have not had a problem nor a leak the system doesn't bleed down either good stuff in my opinion.
