- Jan 7, 2016
- 3,268
I think they will be going upstairs in the bar area of the shop for the short term
Errmmm... what? Jeepers. Here I was proud I had a microwave in my shop.
If got the Shars version. I've watched 3 good videos about them: Stefan Gottswinter (spelling?) Robin, The tool and die guy.Bought a U3 universal grinder.
Comes with attachments for end mills, drills and lathe bits.
No piece of metal in my shop is safe now!
I keep a supply of various sizes of 12L14 or 1245 on hand and have made expanding mandrels simply by drilling, countersinking, threading and slotting. Works great. Braveheart sells replacement screws but they have a very steep taper on the countersink which while it works very well, I haven't found the tool to make that countersink. BTW, a little oil or grease under the screw head allows more expansion.No such thing as a dead zone. You turn down the smallest size that is larger than the diameter you need. Only turn down the length you need so you'll eventually end up with stepped mandrels. There is a seller on eBay (factory, I assume) that seems to sell all Breakheart lathe accessories. The seller name is thirdwheelrider. I keep spares on hand (you know why). Looks like eBay is free shipping on that set. Sorry about that. I didn't think about eBay 'till just now. Also, import clones on eBay for less $$, but I can only guess as to quality. Breakheart = USA made and no problems.
Disclosure: No connection with Breakheart. Just a satisfied customer.
Compressor on hand and up to the task @Bi11Hudson?
13 CFM usually adjusted for 75 PSI. Sufficient?
