[4]
1/8-5/8" 3-16mm No 79/k Jacobs Drill Key Keyed Chuck Arbor Size?
[3]
[10] Like what you see?
calstar
Sep 26, 2013
403
Likes
115
#1
I have an 1/8-5/8" 3-16MM No 79/K JACOBS DRILL KEY KEYED CHUCK and can't find its arbor size. I've been to the Jacobs site and no listing of the 79/K, if you know it please post.
thanks, Brian
wawoodman
himself, himself
Mar 19, 2011
931
Likes
711
#2
You might just have to call them.
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#3
There is a chart on the Jacobs site that provides the details for each of their standard tapers. You should be able to take a few measurements and determine which your chuck has, even though you cannot specifically find a reference to your model of chuck.
http://www.jacobschuck.com/MagentoShare/media/documents/jacobs-technical-information.pdf
There are 9 possible tapers, with dimensions different enough to make a positive ID. I take it you are ordering an arbor of some sort and need to know the proper nomenclature?
chips&more
Mar 19, 2014
2,462
Likes
1,790
#4
What all does it say around the chuck? Sometimes it tells you arbor size.
calstar
Sep 26, 2013
403
Likes
115
#5
First thing I looked at, nada. I emailed Jacobs, no phone contact listed anywhere on the net, guess they don't want pesky customers taking up valuable time. Brian
chips&more
Mar 19, 2014
2,462
Likes
1,790
#6
Brian, well darn! Then that just means a little longer to figure it out. By taking some measurements of the tapered hole and checking with a chart on Jacobs tapers (should be this?) you can find your answer. There is a bit of a spread between the taper sizes. So you shouldn’t be wondering if it’s this taper size or that taper size. Should be able to find your taper with simple measurements and then compare your numbers to the chart. Good Luck…Dave.
wawoodman
himself, himself
Mar 19, 2011
931
Likes
711
#7
Or, just get some modeling clay and stuff it in the hole. Take it out, and you can take direct measurements.
Found a phone no. tel:800-688-8949
[6]
[5] [7]
