11.5 tpi
neilking
Dec 1, 2013
49
can I use a threading dial to cut 11.5 tpi?
Sent from my SM-G920P using Tapatalk
You will need to tell us more to get a useful answer. What lathe? Metric or Imperial lead screws? Do you have the correct change gears (if needed) to do 11.5 tpi? Will the 11.5 thread be straight or tapered? What are you making?
Edit: Answering the following questions might also help your project. Will the thread be required to seal against gaseous or liquid pressure without leaking? If so, how much pressure?
My Kent USA 13x40 with a 8 TPI lead screw, 4" per revolution threading dial, and 32 tooth threading dial gear can be used for 11.5 TPI if always engaged on the same number.
If you have a 11.5 square on your quick change on your lead screw gear box Yes. I am sure the machinists that change the gearing on the end of their lathes will have some interesting comments on this. I say yes with out going out to the shop to check the threading chart on the Clausing but I am reasonably sure it has an 11.5 setting. I re-read your question thus the following comment I would use the same number on the threading dial for each pass. Are you cutting internal or external threads? Maybe both so enjoy. Please excuse the jump to conclusions at the beginning of this response.
Have a good day
Ray
My Grizzly G0602 will cut an 11.5 tpi thread. The thread dial will work with any two marks diametrically opposite each other (1 & 7, 2 & 8, 3 & 9, 4
&10, 5 & 11, or 6 & 12).
southbend 9b, 8tpi lead screw. I ruined this by cutting left hand threads.
yes just use the same number each time. this gives you the same place each time bill
Can't say for others, but my 19" Regal will cut 11-1/2 TPI, and will engage properly on opposite numbers on the thread dial; only if there are quarter threads, do I have to engage on the same number; this applies to any lathe with a 4 TPI lead screw.
