I purchased this lathe thinking it was an early grizzly G4003 but it appears to be "something else". I thought maybe an Enco but can't confirm
It's a 1999 but no manufacturer listed.
I have been going through it and have found a few parts that need replaced/repaired. It needs a new cross-slide handle but I can Fab one up.
The biggest issue is the compound. I only got the bottom piece where it mounts to the cross-slide. I thought I could just buy the grizzly parts to finish it but they don't match up. The compound cross-slide is not the same dimensions as the base that came with my machine.
My Hope is to just find a good used compound assembly or get someone to measure a G4003 compound base and see if it would just bolt right on.
Sent from my SM-N950U using Tapatalk
