I have been looking on/off for last 2 years here on east coast for metal / wood saw. Wanted a ready to use one, not a basket case. Most were in $600-1000 range, and several still needed work. Recently did major repairs to rusty mower deck on my Gravely Pro walk behind, and very tired of the cut-off wheel and jig saw for 1/8 sheet. Something had to change, so said I would buy next one I saw.
Finally bought a "no information available - never been run powered up since purchased" well used 1974 Rockwell 28-300 at a local auction, 20 minutes away, for $60 2 weeks ago. From the three pictures , was obvious it was missing both step pulleys and upper blade guide at minimum, so took a chance for cheap.
Motor does not run, just hums, wired for 220, and 3450 rpm, with capacitor rated @ 110 v. Since original motors were 1725 rpm, it is going away without replacing the cap. Will be replaced with HF 1 hp compressor motor(still have $100 gift card). Rest of unit was well used / abused and jerry rigged. Have it all torn apart, with replacement parts / bearings arriving this weekend. Probably be about $600 into into by time all fixed up, and will have made lots of little things (adjuster knobs for upper guides, lock collars for lower guides, table insert, table align pin, make long tension rod and hardened nut, couple bushings, and return a couple steps on the new pulleys to make belt fit every step the same). Going to take a few weeks to get this back together.
Knew I shouldn't have done it, but looked for standard bandsaw search on FB Marketplace yesterday for fun. Real nice newer complete Jet about 1 hr away just listed for $500. Go figure....
