Here is my recent acquisition. It has been rebuilt: ways, ground and scraped, new lead screw, and other parts, all the gears look perfect, minimal lash in all controls.
It is an awesome looking lathe. Looks just like the LeBlonds that was in the first shop I worked in. I got to run them a little bit, the owner those was his babies
The generator is finished mechanically, now I need someone to wire it. The Witte diesel is running but still needs an exhaust and cooling system which I can do. I might have it ready for Pottsville.
Did I mention the LeBlond has a taper attachment? When I talked to the factory man he said that was worth a lot.
One problem; when they rebuilt it they ground off the serial number and didn't re-stamp it. By describing the machine and sending pics the factory guy could give me a close approximation of the exact model but couldn't be certain. He said they often run into this problem. I cannot fathom why anyone re-building a machine would not re-stamp the serial. This will cause problems when ordering parts.
Anyone know how to resurrect a gone serial number? I know cops can do it on firearms.
